hpop pressure?
Old Feb 14, 2006 | 07:06 PM
oldbird1965's Avatar
oldbird1965
hpop pressure?
At WOT, what is the pressure of the hpop? I heard it should be 3,000 psi, mine is 2,500 psi. It doesn't vary any at WOT, stays at 2,500psi. Is this normal?
Old Feb 14, 2006 | 09:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Are you taking a direct pressure reading, or using a scan tool?
Old Feb 14, 2006 | 09:53 PM
oldbird1965
Cookie88, I used a direct reading. Thanks
Old Feb 14, 2006 | 10:39 PM
cookie88's Avatar
cookie88
FTE Emeritus
3000 is the upper limit of a stock HPOP, but I think 2500 still falls into the acceptable range. If no one else replies I'll look it up tomorrow. Since the pressure is rock steady at 2500 I'd call it good, if not just a little bit weak.
Old Feb 15, 2006 | 06:00 AM
1997F-350's Avatar
1997F-350
i would think if you are holding 2500 psi on a 15* pump you are great.
Old Feb 15, 2006 | 07:31 PM
oldbird1965
I was kind of thinking I was OK or maybe a little weak. Just curious, what would a SD 17* maybe put out?? Thanks guys!
Old Feb 15, 2006 | 08:22 PM
barebackjake's Avatar
barebackjake
its the same pressure just 7cc more oil per revoloution
Old Feb 17, 2006 | 10:21 PM
18vtx00's Avatar
18vtx00
Question
sounds good to me, are you diagnosing and issue or just looking for potential problems???
Old Feb 17, 2006 | 10:40 PM
oldbird1965
Just looking for potential problems. My truck pulls my 5er great but goes flat at upper rpm's. Thinking about changing to a SD HPOP.
lemonshindig
May 24, 2014 05:25 AM
ramsay
Sep 28, 2013 08:48 AM
VIPERK30
Jun 22, 2012 10:47 PM
danskool
Jul 13, 2008 02:26 PM
John311t
Nov 2, 2006 04:34 PM
