Speed Sensor headache
Old May 28, 2018 | 10:15 AM
Robdamedic's Avatar
Robdamedic
1995 F150 5.8 Eddie Bauer, bought used, 180k miles. Drove it for 2 days, speedo stopped working, wont go over 45 mph. Searched the forums, sounds like a speed sensor. Tranny is E4OD. Only has rear diff. speed sensor. Replaced it with OEM part. Nothing. Gave up, brought her in to the shop. "Transmission guy" at the shop confirms its the diff. sensor. Worked for four hours. No speedo again, no more than 45 mph. Bad sensor?? Tried a third time. No luck. Any ideas? Experience? (This tranny does not have a tail mounted sensor.) TIA
Old May 28, 2018 | 10:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Has anyone electrically verified that the wiring to the sensor is good? Looking at the wiring is next to useless, there has to be an electrical check. Has anyone checked for codes?
Old May 28, 2018 | 12:18 PM
Robdamedic's Avatar
Robdamedic
No Mark, no one including myself have checked for codes. I brought my OBD 2 with when I looked at it, but it is a 95, OBD 2 is only good on 96 and up. Wise to invest in an OBD I ? If so, do you know where the plug in is located? Thanks very much.
Old May 28, 2018 | 10:19 PM
Mark Kovalsky
The plug is under the hood. I don't remember exactly where. You can invest in either an OBDI reader or a paper clip. https://www.troublecodes.net/ford/
Old May 29, 2018 | 07:32 AM
Robdamedic's Avatar
Robdamedic
Thanks Mark. Found the plug, tried the paper clip. No flashing. Bad ECM?? Buy OBD 1? Yes, but no engine light is on. Will it still pull trouble code? Check engine light comes on during starting as usual. Only idiot light that stays on is ABS light.
Old May 29, 2018 | 09:02 AM
Mark Kovalsky
And now you've confirmed that you have an issue with getting vehicle speed to the PCM.
If it won't output codes there is a good chance the PCM is bad.
Old May 29, 2018 | 09:50 AM
Robdamedic's Avatar
Robdamedic
Thank you very much for your quick replies. Bad computer did cross my mind. Will go pull one from u pull yard. Let you know. Thank you again.
Old Jun 9, 2018 | 08:26 AM
Robdamedic's Avatar
Robdamedic
Mark, thank you so much for your input. The ECU was fine. Turns out the transmission went belly up. Only first gear works. When applying the brake and giving her some gas in any gear, a whirring and metallic clink can be heard coming from the tranny. Guess I cant complain. Paid $2k for her plus the $800 for a tranny rebuild brings it right up to the low end of book value. She has no rust, a near perfect interior, mag wheels and a great stock paint job. All in all I am pretty happy with her, even at $3k. I just wish the seller was upfront about the issue. Thanks again.
Old Jun 9, 2018 | 07:19 PM
kopfenjager's Avatar
kopfenjager
how is this 335 related?
granny_rocket
Apr 2, 2015 11:07 PM
Blankie
16
Aug 27, 2013 08:33 PM
LonnieD
Sep 22, 2010 01:18 PM
nanufree
Dec 19, 2005 12:33 PM
xraytommy93
Nov 10, 2003 03:21 PM
