Vehicle speed sensor replacement
Old Apr 2, 2015 | 01:14 PM
granny_rocket's Avatar
granny_rocket
I went to replace my vehicle speed sensor last week. The original one was giving me a shaky speed reading over 65 mph which is why I replaced it. When I put the new one and I'm now getting a shaky speed on the speedometer at around 45 mph. I bought the part from advanced auto parts so it's not a genuine Motorcraft part. Has anyone run into this kind of trouble before or is there something that needs to be cleaned inside the diff? Just looking for thoughts on how to fix it or should I return it and get a genuine Motorcraft part? Thanks in advance
Old Apr 2, 2015 | 10:34 PM
oldbird1965's Avatar
oldbird1965
I would, my motorcraft one works good. Make sure you check the wiring pigtail good.
Old Apr 2, 2015 | 11:05 PM
fordpride's Avatar
fordpride
Getting one from ford is a better option but still not guarantee it will fix it. When I changed mine I got three different one from ford before it stopped bouncing
Old Apr 2, 2015 | 11:07 PM
madpogue's Avatar
madpogue
Quick (well, kinda) test - put the old sensor back in and drive it. If you get the old functionality back (OK up to 65), then the new sensor is indeed a POS. If it's flaky over 45 (or anything lower) with the old sensor, then you've got another problem - pigtail, wiring, tone ring, etc.
oldstroker41
Oct 6, 2012 10:35 PM
nanufree
Dec 19, 2005 12:33 PM
Big_worm
Nov 21, 2005 04:27 PM
paulcalif
Nov 5, 2003 09:19 AM
Electric1
Jan 2, 2002 03:59 PM
