speed sensor woes
Old Nov 28, 2005 | 11:40 AM
nanufree's Avatar
nanufree
Question speed sensor woes
I have a 1996 E150 with a 5.8L and an E4oD trans. Engine light comes on and computer says speed sensor A malfunction. The speedometer works. Where is the speed sensor that controls the transmission? Transmission works but does not go into overdrive and seems to be lost as to when to shift. Works fine in Drive 1 and Drive 2 but floats when in Drive. I replaced the sensor over the differential with no change results. any help would be appreciated
David
Old Nov 28, 2005 | 12:01 PM
Casey's Avatar
Casey
There is no speed sensor A. There is a shift solenoid A.
There is a turbine speed sensor (TSS), output speed sensor (OSS) and a vehicle speed sensor (VSS), but none of them are called speed sensor A.
You problem sounds just like a shift solenoid failure, not a speed sensor failure.
Old Nov 28, 2005 | 05:16 PM
nanufree's Avatar
nanufree
You are right. The auto Scanner said it is the vehicle speed sensor. Code PO500. My question is where is this sensor? Thanks David
Old Nov 28, 2005 | 07:02 PM
Casey's Avatar
Casey
The vehicle speed sensor is the one on top of the differential.
Since you already changed that, it probably isn't the sensor. It could be a damaged tone wheel inside the differential or a bad wire between the sensor and the computer.
Unless this is one that has the VSS on the end of the speedo cable at the rear of the transmission....I can't remember that far back.
Look at the rear of the trans. If the speedo cable attaches there and there is a sensor with two wires, that's the VSS.
Old Nov 28, 2005 | 07:35 PM
nanufree's Avatar
nanufree
Question
When the two wires are attacted to the sensor the speedometer works. When the wires are not attacted to the sensor the speedometer fails to work. Is it possible for the sensor to work for the speedometer and not the transmission control? I have looked and it does not appear to have a gear driven sensor or speedometer cable going to the transmission,just a wiring harness. Thanks again David
Old Nov 28, 2005 | 08:21 PM
Fordcr's Avatar
Fordcr
Casey: Did the 96 stil have th PSOM? my 92 lost the tran control and cruise but not the speedo. A different PSOM solved it.
Old Nov 28, 2005 | 09:14 PM
nanufree's Avatar
nanufree
Question
What is a PSOM, where is it and how can I Test it? Thanks David
Old Nov 29, 2005 | 07:45 AM
Casey's Avatar
Casey
That's what I don't remember.
Old Nov 29, 2005 | 01:29 PM
subford's Avatar
subford
The PSOM (Programmable SpeedOmeter Module) feeds the PCM the speed information and the PCM shifts the Transmission.
And YES the 1996 had a PSOM and that may be your problem but if the speedometer bounces a little it could be the a damaged tone wheel inside the differential.
The speedometer is in the PSOM module.
Old Dec 19, 2005 | 12:28 PM
clerk's Avatar
clerk
Our church has a 95 e350 bus conversion with the E40d and a 460. When we first got it the speedometer started malfunctioning. Then it straightned out but the trans failed to shift properly. I swapped it out for another PSOM (complete speedometer) out of another one. Presto -- no more problems.
Hope that helps.
Old Dec 19, 2005 | 12:33 PM
nanufree's Avatar
nanufree
Thanks for the info. I will give it a try. DAvid
