oil restricted pushrods
Old Jun 16, 2018 | 12:26 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
Anyone know where I can get the oil restricted pushrods, other than TMeyer? I have a 400 I'm building with retro-fit roller cam. I put the grooved cam bearings in, and I suppose I can run regular pushrods, but really going for longevity here so think I should probably put them in.
Old Jun 16, 2018 | 08:59 PM
reebadoo's Avatar
reebadoo
depending on your build. i would suggest you get the measurements and get them from tmeyer. i did the same rebuild earlier this spring and now im prepping my pickup to install the engine and transmission. i know my push rods were shorter than expected. but if i can find the receipt or packing slip for the push rods i will let you know what they are and where they are from!
what cam are you running?
Old Jun 17, 2018 | 11:18 PM
TXTrailerdaddy
I got everything else from Tmeyer. He's a great guy, and I don't want to get into it, but I'm just looking for another source.
Old Jun 22, 2018 | 10:25 PM
reebadoo's Avatar
reebadoo
im sorry im just not sure where else to get them
Old Jun 23, 2018 | 12:38 PM
baddad457's Avatar
baddad457
If you're looking to improve the oiling to the lifters, you can install a "T" in the front oil pressure port and run an external line over the top to the rear pressure port, that will equalize the pressure and supply to the lifter galleries.
stormchaser70
Jul 11, 2009 03:50 PM
66f100352
18
Feb 25, 2008 12:17 AM
hoxiii
Sep 12, 2007 11:05 PM
father/son
Apr 19, 2007 01:14 PM
jeffbran
16
Apr 23, 2004 01:07 PM
