Shut Down No Start
Old May 31, 2018 | 01:22 PM
  #61
Tideman's Avatar
Tideman
nope. Under the ”C” clip on top of the injector. I was hitting the “C” clip to get it out and slipped and hit “that metal ring just below it” what ever it’s called , and broke it.
Old May 31, 2018 | 05:53 PM
  #62
Tideman's Avatar
Tideman
I broke one of these. You can see the pattern of the”C” clip on top. I got another one.
Old May 31, 2018 | 06:06 PM
  #63
Tideman's Avatar
Tideman
On the same note, Mark you were right. Its the HPOP, an “O” ring or the STC fitting. I’m not a happy camper. One of my grandsons is coming home from Collage this weekend to help me. I’ve got no one to point the finger at but me. I put this engine together.
Old May 31, 2018 | 08:14 PM
  #64
TooManyToys.'s Avatar
TooManyToys.
Doesn't mean it was an install error...........
Old Jun 1, 2018 | 05:36 PM
  #65
Tideman's Avatar
Tideman
Thanks Jack!! Got pump off finally and don’t see anything obvious. Yellow “O” ring in proper place and so was the other one. Is this a reman pump or are those markings normal. Really didn’t notice that when installing. Big question. How do you test the pump?
Old Jun 1, 2018 | 07:44 PM
  #66
TooManyToys.
Setting up a bench test rig should not be that hard, but I don't know anyone who has done so. Pumps are not that hard to test. Our old aircraft hydraulic division had a ton of test benches.
Can't tell you anything about the HPOP labels though.
Old Jun 1, 2018 | 07:57 PM
  #67
Tideman's Avatar
Tideman
I found a Navastar test procedure. Will do it but don’t really have a lot of faith in it. Last thing is to put it in and test before I put it all back together. (That is what I should have done before I took it out)
Old Jun 1, 2018 | 08:45 PM
  #68
m-chan68's Avatar
m-chan68
Bad IPR valve???
Old Jun 1, 2018 | 09:01 PM
  #69
Tideman's Avatar
Tideman
No, I did air test and had a pretty hefty leak. Re sealed all passenger injectors and still had a considerable leak. I’m trying to figure out how to do a test on pump outside of engine. All ideas welcome
Old Jun 1, 2018 | 09:07 PM
  #70
bismic's Avatar
bismic
Originally Posted by m-chan68
Bad IPR valve???
Mike - have you seen an IPR valve failure cause zero pressure build when cranking?
How about a bad oil rail leak causing zero cranking pressure build?
Old Jun 1, 2018 | 09:18 PM
  #71
Tideman's Avatar
Tideman
I did nipple cup seals when i did the engine about 15,000 miles ago. Didn’t do new nipple cups. I took the CV out of the valve cover and have same leak on drivers side. Praying it’s not branch tubes.
Old Jun 1, 2018 | 10:03 PM
  #72
wedge542's Avatar
wedge542
can you test the ipr valve?
Old Jun 1, 2018 | 10:07 PM
  #73
firedaniel's Avatar
firedaniel
Just a question and I may be off but did you check the low oil pressure pump? It would feed the hpop
Old Jun 1, 2018 | 10:09 PM
  #74
Tideman's Avatar
Tideman
Yes. I’ll do that tomorrow I haven’t tested it outside of the engine.
Old Jun 1, 2018 | 10:35 PM
  #75
Tideman's Avatar
Tideman
I’m sorry I didn’t see your post until I logged off and was reading mail. To answer it is yes I did at oil filter. Thanks tho
