Shut Down No Start
Old May 27, 2018 | 11:52 AM
  #46
Tideman's Avatar
Tideman
Thanks for the ideas. I tried a few things this morning including unplugging the EBP. Nothing. Im with you Mark (I’m still in denial) some “O” rings blew or HPOP just died. It looks like Wednesday before i can get it home and dig into it. Also having everything off will help me chase the electrical problem. Stay tuned, I'll be crying on the boards shoulders soon. Thanks
Old May 30, 2018 | 09:48 AM
  #47
wedge542's Avatar
wedge542
You floating around down your way today,hope alls well after storm, any news on the truck?
Old May 30, 2018 | 07:11 PM
  #48
Tideman's Avatar
Tideman
Just got it home about 30 min ago. Havent had time to do anything on it. Going to start early in the morning . Rain was so so, wind not much. You know the news they show the worst cases. Air test first then if not that, IPR. You know when something keeps creeping up in your mind. Well the IPR does. Not sure if it shorted it could cause all my DTC’s. We’ll see. Thanks for asking
Old May 31, 2018 | 09:26 AM
  #49
Tideman's Avatar
Tideman
Air test. Had a lot (A LOT) of air between #3 & #5 here is the first thing I found. Dummy plug and Stand Pipe looked good.
Taking a break then will continue to look. On the bright side, about a month ago I ordered 8 sets of alliant injector “O” ring kits just to have for my grandsons trucks and mine
Old May 31, 2018 | 09:27 AM
  #50
Tideman's Avatar
Tideman
That was top ”O” ring on #3. Sorry
Old May 31, 2018 | 09:35 AM
  #51
bismic's Avatar
bismic
Takes a pretty good sized leak to not get ANY ICP. I guess you found it. Hopefully the drivers side is OK.
Old May 31, 2018 | 09:39 AM
  #52
Tideman's Avatar
Tideman
Had nothing on the drivers side. Hard to believe that “O” ring let that much air/oil thru. Will start back looking in a few minutes.
Old May 31, 2018 | 10:36 AM
  #53
TooManyToys.'s Avatar
TooManyToys.
Was that a nick from coming out?
If not, did any of the other injectors 0-rings have that type of mark at the same orientation?
Old May 31, 2018 | 12:48 PM
  #54
Tideman's Avatar
Tideman
Jack, It could be. #1 had a small rough spot but from what im seeing on 1-3-5 where the leak was the loudest, it doesnt look like it could have caused a shut down. Dummy plug wasn’t exactly smooth but really wasn’t rough either. Now I have another problem in that I broke the “D” ring below the injector clip at the top of #1 injector. Been calling around to see if any shop has a bad injector laying around that they would sell me . The only air leak I got was from there.
Old May 31, 2018 | 01:00 PM
  #55
bismic's Avatar
bismic
Injector clip: Part # W301222
$3-$5. I would think most dealerships should have one.
https://www.tascaparts.com/oem-parts...aneous-w301222
Old May 31, 2018 | 01:03 PM
  #56
TooManyToys.
And if not what Mark just posted, the closest, cheapest I found on eBay
https://www.ebay.com/itm/Fuel-Inject...8AAOSw8Mda81le
Old May 31, 2018 | 01:07 PM
  #57
bismic's Avatar
bismic
I guess I misread it again. You posted it wasn't the clip, it was "the D-ring below the clip"? Sorry!
Old May 31, 2018 | 01:08 PM
  #58
Tideman's Avatar
Tideman
Mark, I called it the wrong thing. My bad. Its the metal piece inside the top of the injector just below the clip and above the “O” ring. Sorry.
Old May 31, 2018 | 01:14 PM
  #59
Tideman's Avatar
Tideman
Thanks Jack. Never thought of e-bay Will try calling around first.
