EGR Delete Codes
Old Apr 15, 2018 | 02:33 PM
  #31
arayray94's Avatar
arayray94
MAF Values:
KOEO:
0 g/s
Idle:
35.9 g/s
High idle:
64 g/s
2500 rpm:
135 g/s
Cruising 70 mph (previous data from post #23)
180 g/s
This was all at operating temperatures.
Old Apr 15, 2018 | 10:30 PM
  #32
BLADE35's Avatar
BLADE35
your 2500rpm G/s looks really high compared to marks
MAF needs troubleshoot could be bad sensor or bad Vref
Old Apr 15, 2018 | 10:44 PM
  #33
arayray94's Avatar
arayray94
I'm going to do the MAF volt check mentioned in post #21, what conditions should I test at? Idle, high idle and 2500rpm again?
Old Apr 15, 2018 | 11:00 PM
  #34
BLADE35's Avatar
BLADE35
looking in the 6.0L Bibble there is a chart for comparison for MAF G/S to MAF Volts the chart was not in grid form so kinda guessing but relatively close you MAF is 1 Volt Higher then OEM Spec that's a lot considering the system operates on 5 volt Vref
you need a DVM to troubleshoot the sensor make sure its getting Vref and ground etc....if those check ok the possibly consider replace the sensor
Ideally you would also post MAP Values with MAF values all taken at same time since the PCM is calling P006a Map/MAF Corralation
Old Apr 15, 2018 | 11:05 PM
  #35
BLADE35's Avatar
BLADE35
SENSOR OPERATING VALUES PDF
https://www.ford-trucks.com/forums/attachment.php?attachmentid=71501&d=1364848489
6.0L Bible
https://www.ford-trucks.com/ford-man...eTableBook.pdf
full page engine wire diagram
https://www.ford-trucks.com/forums/attachment.php?attachmentid=172527&d=1485755349
id try the troublesoot in post 21 too
maybe the hotwire is messed up
Old Apr 15, 2018 | 11:20 PM
  #36
arayray94's Avatar
arayray94
Awesome information, thank you!
Old Apr 16, 2018 | 03:47 AM
  #37
bismic's Avatar
bismic
MAF sensor flow and voltage correlation
Edit - anyone else getting the "Dallas Cloudfare" error when trying to open an attached pic?
I can't view my own attachment, but maybe others can.
Old Apr 16, 2018 | 03:56 AM
  #38
David7.3's Avatar
David7.3
Great info guy's keep it up
Old Apr 16, 2018 | 07:21 AM
  #39
Tideman's Avatar
Tideman
Mark on some post here recently all i see is a small square. When i tap on that sometimes i get a picture some times it states that photo could not be opened. By the way your post had 1 picture. Dont know what “Dallas Cloudfare” is.
sorry for the hijack
Anthony Castrovinci
6.4L Power Stroke Diesel
Apr 11, 2019 07:16 PM
strokenboost
6.7L Power Stroke Diesel
Jan 13, 2018 09:54 AM
openexcess
Jun 12, 2011 05:12 PM
FI460
Aug 20, 2009 09:31 PM
RMoore
Mar 3, 2008 11:39 PM
