codes codes CODES!!!!
Old Feb 28, 2008 | 04:34 PM
RMoore's Avatar
RMoore
Post codes codes CODES!!!!
Hey guys,
So far so good but still some problems to work out has enyone heard of a code #P132B it came after three other codes p0401 , p0403 , p0405 and these are all related to the egr . Could this be the reason for no power and the shaking at 50 mph! I cant find anything for the p132b ! Possable it is a curcuit prob!!!?
R Moore
Thanks for all the HELP so far !!!!i sure do appreciate it !!
f 350 2003 6 liter 6 inch lift 35 in tires 4 inch no cat exhaust afe intake arp studs afe intake , New oem turbo , and a new egr on the way !
Old Feb 28, 2008 | 04:43 PM
OZX1's Avatar
OZX1
Originally Posted by RMoore
Hey guys,
R Moore
I farmed this information from "another" site...
The P132B code usually show up after the 06E17 flash with after market stuff on them or leaky stock stuff, up pipes, map hose, CAC boots, sub par turbo. The 06E17 flash disables the EBP sensor and relies heavily on the MAF sensor thus the incompatibility with after market intakes. Many of the after market intakes relocate the MAF sensor slightly and it messes up the signal. Yes the oil type filters can raise cane when the oil gets on the MAF sensor.
AND
Loose the AFE air filter, reinstall the stock one and the code will probably go away.
Old Feb 28, 2008 | 04:49 PM
RMoore's Avatar
RMoore
Thanks for the info but i think that the stock filter is garbage it has a gap in the bottom left hand side and it sucks dirt in real bad, I know this because my turbo had chunks and knicks in the vanes on the intake side and after i installed the afe and new turbo seems to be good . Now i know it actually does nothing as for power gains but it is easier to clean than to replace ,man that thing is a pain in the booty to change ! So do you think my egr valve is causing the truck to shake at 50 mphs ?
Old Feb 28, 2008 | 04:58 PM
OZX1's Avatar
OZX1
With three flow related EGR codes... Yes, it's possible. RU getting a lot of smoke? Do you still have the same turbo with chunks and nicks in the vanes on the intake side? That'll kill ya! My opinion is buy a non leaky stock intake, replace the dinged-up turbo and replace the EGR (or delete the thing).
Old Feb 28, 2008 | 05:08 PM
RMoore's Avatar
RMoore
yep i just put a new one on and the egr valve is on the way , I got a real good deal on a brand new turbo for my o3 6 liter total 996.12 at Bell Ford in Phoenix and thats including tax but does not include the selinoid valve for the electronic waste gate the goes in the turbo and those are 351.59 and i picked this up at Galpin Ford in Presott,Az
Thanks oh and yes it is smokin like a blueish grey but nothing a wot
Old Feb 28, 2008 | 05:12 PM
OZX1's Avatar
OZX1
The EGR valve will do the trick... I'm still supporting my stock intake position. Look on craigslist.org for a replacement.
Old Feb 28, 2008 | 05:14 PM
RMoore's Avatar
RMoore
Cool im doing it rite now thanks for all the help ozx3+1 !!!
Old Feb 28, 2008 | 05:20 PM
OZX1's Avatar
OZX1
Anytime... BTW, The "solenoid valve for the electronic waste gate" is not for a waste gate... The variable geometry turbo does not have a waste gate. The solenoid that your speaking of controls the variability to the pitch of the impellers, and could also be keeping your turbo from boosting at all. Do you have a boost gauge? Are you getting any boost?
Old Feb 28, 2008 | 05:25 PM
RMoore's Avatar
RMoore
Yes im getting boost about 28 lbs but acording to ford it is a wast gate for the exaust but i realy dont care i just baught one for 351.59 and installed it in the new turbo!! its got the boost , just slugish and slow and vibrating at 50 mph i do have a brand new egr on the way ford had none in stock and they are 350 bucks or so i hear!!!
Old Feb 28, 2008 | 05:26 PM
OZX1's Avatar
OZX1
Ah, good then... I thought you may have used your old one...
Old Mar 3, 2008 | 05:21 PM
RMoore's Avatar
RMoore
OK i have the new egr valve installed! I do have more power but no torque i put the front tires on a curb and it would not go over !! It idles fine and it revs great but under a load the rpms stay at 1200 !!! could i have a torque converter problem or icp problem or perhaps injector problem so far ive got a new 03 turbo a new vgt silanoid and egr valve. So far the help i have gotten has been very helpfull and i sure do appreciate it !!!!
R Moore
Old Mar 3, 2008 | 10:39 PM
bismic's Avatar
bismic
I'm still don't understand the waste gate discussion. I did not think that we could/should get waste gates for these VGT's. Are you sure that it was a waste gate? And if so, maybe the computer does not know how to control the new system? I don't know much on the turbo and the controls (definitely interested in learning), but what you posted seemed confusing to me.
Old Mar 3, 2008 | 11:16 PM
RMoore's Avatar
RMoore
well mark i was told from ford when i bought my new turbo ( and i got a really good deal ) they told me that the turbo does not come with the silanoid valve in it ! That valve is what moves the vanes mine has nine in the exhaust side of the turbo so i gues in a sence it is a waste gate for exaust and i think for back pressure as well ! Now im not a deisel mechanic and dont claim to know what i am talking about thats why im in this forum, but i took my turbo out myself because when STEVE COURY FORD put the heads on my truck for the second time they did not hook up the pipe that goes to the egr cooler and i had no power , so with no warranty left $%#k FORD ill fix it my self and when im done im trading it in for a DODGE lol sorry to vent but im putting way too much money in my truck!! just make sure that if you ever take your truck to a dealer make dam sure they put the problem in writing even if it is under warranty !!!!!
Old Mar 3, 2008 | 11:39 PM
bismic's Avatar
bismic
RMoore - thanks for the explanation, I understand now. Sorry to hear about all the troubles. Sounds like the dealership service dept. was a little sub par. Hopefully someone can pick up from here and get you going.
