Codes for bad Cats....?
Old Oct 19, 2017 | 08:58 PM
MtnMerk's Avatar
MtnMerk
If the Catalytic Converters go bad, will there always be codes thrown.....?? Brief history, just did the Phasers, chains, etc.....starts and runs great. Until you put it in gear. Engine still runs fine, but absolutely no power.......??? undriveable.....Vehicle 2006 F150 Lariat, automatic, RWD.......175K
Old Oct 19, 2017 | 09:46 PM
steve(ill)'s Avatar
steve(ill)
was the converter plugged BEFORE you did the phasers ? My first guess would be that you have the timing chains off a tooth or two.
Old Oct 19, 2017 | 09:57 PM
MtnMerk's Avatar
MtnMerk
Upon initial startup after doing the phasers, etc......codes were referencing cam position sensors....went back in and corrected for being off a tooth.......Now it starts and runs fine, until put under a load. No codes at all.....!! I'm thinking that the cats may have been on their way out prior to doing the front end.
I just hate to throw any money at it without a reasonable expectation of success.
I'm old school, never replaced any parts till we knew they were bad.
Old Oct 19, 2017 | 11:02 PM
Tedster9's Avatar
Tedster9
An old school mechanic's vacuum gauge will reveal any restriction in the exhaust in about 30 seconds.
Old Oct 20, 2017 | 09:12 AM
steve(ill)'s Avatar
steve(ill)
Take the CAT loose from the exhaust pipe and run a mile down the road and back to test... You will be loud and get other codes, but will be a good restriction test.
Old Oct 20, 2017 | 09:14 AM
alloro's Avatar
alloro
Yes there will be. It might take a couple of start up and shutdowns for the CEL to turn on because some codes first set as pending and later escalate to an actual trouble code where the CEL will turn on.
allen62
1997 - 2003 F150
20
Nov 8, 2018 12:25 AM
cottrellp
2004 - 2008 F150
Jun 13, 2010 06:21 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
bandito20
Jun 3, 2005 12:40 AM
GFDHoytJr
Nov 27, 2003 09:04 AM
