P0420 & P0430 codes
Old Jun 13, 2010 | 10:33 AM
cottrellp's Avatar
cottrellp
P0420 & P0430 codes
I have a 2007 F150 XL 4x4 that the ces just came on and the codes were P430 and P420. I haven't noticed any difference in the way the truck is running. Any suggestions on what might be wrong?
Old Jun 13, 2010 | 10:53 AM
jr105's Avatar
jr105
The codes are "catalytic converter efficiency below threshold" banks 1 & 2. This could be bad cats or some other problem you will have to research causing them to throw these codes.
Old Jun 13, 2010 | 11:10 AM
cottrellp's Avatar
cottrellp
If it was bad cats wouldn't the truck be running rough or not at all? What are the other possiblities that could be causing this code?
Old Jun 13, 2010 | 11:47 AM
powersmoked's Avatar
powersmoked
I doubt it is the CATS. I would bring the maintenance of the truck up to par ie. a tuneup. I would then clear the codes and reboot the pcm. keep you eyes out for more codes especially pending codes
Old Jun 13, 2010 | 06:21 PM
formula74's Avatar
formula74
Most likely an oxygen sensor, take it to an Advance or Autozone and their reader will tell you more, didn't your reader give any info with the codes. I do this all the time for customers at one of the places above. Also check out the attached links :
P0420 Error Code: Catalyst System Efficiency Below Threshold (Bank 1)
Double Trouble Code P420 P430 - OBD-Codes.com
Tile man
2004 - 2008 F150
Apr 18, 2017 08:51 PM
Stevenmed
2004 - 2008 F150
Mar 11, 2016 10:28 AM
Villengineer
Sep 30, 2014 03:53 PM
BigDudeLittleTruck
1983 - 2012 Ranger & B-Series
Jul 20, 2012 12:49 PM
jjc103
2004 - 2008 F150
Aug 3, 2009 06:52 PM
