poor performance
Old Nov 26, 2003 | 07:24 PM
GFDHoytJr's Avatar
GFDHoytJr
poor performance
I have a 1990 f250 with a 351 and upon first starting up it runs fine but after a couple minutes of driving time you can actually see it lose some rpm(a couple hundred). From then on it just does not have the accelleration it does when cold. I was thinking maybe a plugged cat. Any input would be greatly appreciated.
Thanks
Old Nov 26, 2003 | 08:11 PM
EPNCSU2006's Avatar
EPNCSU2006
It could be a number of things causing those symptoms. Have you pulled the codes? If not, that's a good place to start. It could be that a sensor is not reading correctly and causing the computer to run the engine with the wrong fuel/ignition curves when it gets into closed loop, but runs good in warm up mode.
Old Nov 26, 2003 | 08:54 PM
GFDHoytJr's Avatar
GFDHoytJr
Would I have any stored codes without a CEL ? I will check though
Old Nov 27, 2003 | 09:04 AM
circledirt's Avatar
circledirt
Yes, check for codes first. Some codes when set will cause ecm to not advance timing.
