2017 remote start
Old Oct 18, 2017 | 09:07 AM
  #46
roadpilot's Avatar
roadpilot
Originally Posted by Steve White
DL3Z-19A390-B. Ford Remote Access System (For app-based unlock)
That's the part number I ordered ~1 year ago. What they sent me had part number DL3J-15603-AA on the actual modem. Worked fine, nonetheless. Will see if it works on the F350 with a different VSS soon.
Old Nov 1, 2017 | 01:18 PM
  #47
swankerme's Avatar
swankerme
Alright, I'm a bit confused here...
I purchased the OEM Remote Start system. Ford Perimeter Plus + Bi-directional Antenna + Key Fob. I can't seem to find a clear answer: do I NEED to visit a dealership for IDS activation? I have used FORScan to activate the remote start in the computer and cluster settings.
I will NOT be using my phone to remote start, only the key fob.
Old Nov 1, 2017 | 01:22 PM
  #48
ctimrun's Avatar
ctimrun
No you don’t need to go to the dealer if you have FORScan. You just need to be sure to activate it in the two different modules I wrote about above to make it work. I believe it is the body control module and the instrument cluster module.
Old Nov 1, 2017 | 01:29 PM
  #49
swankerme's Avatar
swankerme
Excellent. I'll give it a try when I get home!
Old Nov 1, 2017 | 03:30 PM
  #50
swankerme's Avatar
swankerme
How do you program the new key fob? I can't seem to figure out how to activate/program the VSS module or the key fob.
I can't find factory instructions for a 2017 anywhere.
Old Nov 2, 2017 | 04:21 PM
  #51
nonrev59's Avatar
nonrev59
Is the factory installed remote start a bi-directional one?
Old Nov 2, 2017 | 05:43 PM
  #52
Poncho450's Avatar
Poncho450
I thought I'd read that the modules have the same part number? If so, here's what I used on my 2016. If not, sorry for any confusion.
http://www.fordservicecontent.com/fo...structions.pdf
Old Nov 2, 2017 | 05:52 PM
  #53
Brother_Bluto's Avatar
Brother_Bluto
The factory remote start is not... but you are generally close enough to see it start up. The optional Long Range bi-directional kit obviously is, but requires an additional small FOB & antennae. The optional smart-phone kit & app will confirm the start.
Old Nov 2, 2017 | 11:05 PM
  #54
db9938's Avatar
db9938
OK, I am not sure how relevant this data is, or useful is, if there is a difference in FOB's. My truck came with factory remote start, and it is a switchblade style key/fob. It has a 194 yard range, at least, range. Stood and the window of my office, lock, start x2, saw the lights. It could be longer, as this was LOS.
This said, on my last truck, I had an astro-start system, and it had a similar range. But it took me 5 hours to install. Everybody under 30 should have to install one of these once in there life.....
Old May 8, 2018 | 12:12 AM
  #55
dkllw1's Avatar
dkllw1
can i use a ford remote with the remote start button will work?
this what my key looks like
this is what i want to buy to use i know i can program the key to the truck. but will the start button work on this key with the unit you show in the video?
Old May 8, 2018 | 12:56 AM
  #56
AK-AlumADuty's Avatar
AK-AlumADuty
I’m in a similar pickle- I bought my truck as a “certified pre-owned.” It also did not come with factory remote start (just keyless entry with flip key). A Ford remote start was added remote start with the separate key fob.
I want the key like he’s mentioning and know I can go to https://northcoastkeyless.com/shop/f...-pn-164-r8134/ and purchase a new/used key. I know with the flip keys, you have to change the key by knocking the roll pin out and removing the key from your old fob and install on the new fob. One thing I don’t know, if I purchased this new flip key fob with factory remote start (4 button) will it work after reprogramming? My thoughts would be to purchase two of these keys, reprogram and ditch the factory keys & additional key fob for remote start. Make sense?
Old May 8, 2018 | 07:06 AM
  #57
mobil1's Avatar
mobil1
4wd Low
Will not work different frequency the 3 button is on 315mhz the 4 button is on 900mhz
Old May 8, 2018 | 10:27 AM
  #58
AK-AlumADuty
Any way to change the frequency? WTHF! My new acronym- What the Heck Ford!
Old Dec 10, 2022 | 09:44 PM
  #59
jrod270's Avatar
jrod270
4wd Low
Does the truck have to have sync 2 to be able to do this? my 18 f250 is an XL
dickiefrank
2009 - 2014 F150
34
May 20, 2018 06:58 PM
Fordsareking
Dec 31, 2017 11:56 AM
Steve White
Dec 18, 2017 10:14 AM
sims1dh
Jun 21, 2017 05:02 PM
Cdy1
2009 - 2014 F150
Nov 24, 2013 08:48 PM
