2017 remote start
I don't like Ford's solution for having a separate fob for the remote start and will buy new keys with the remote start button in them if possible. I am also open to not doing the key fob and just doing the cell phone app to start if others like this option.
Don't know if it matters or not but I've got the XLT Premium trim. So what's the best way to accomplish this using ford parts? I already messaged Bobby at Banner but I think I should figure out the way I want to go before bugging him.
Here's what you need:
FT4Z-19A351-A 2015-17 F-150 Scalable Security System Kit (Works on SD too)
DL3Z-19A390-B. Ford Remote Access System (For app-based unlock)
FORScan with extended license if you do not have a dealer close by or want to pay one. (You'll also need a CAN-enabled OBD adapter, I recommend the OBDLink MX)
If you want to use keyfobs, you'll need an antenna and obviously keyfob. I did not implement this option so I do not have part numbers available.
Installation is easy.
1. Install the security system module. It's one simple plug and play harness. It takes more time to zip-tie the module in place than connect the wires.
2. Activate & test the security module.
3. Install the remote access module. It's one jumper that connects to the security module installed in step 1.
4. Activate remote start features on the truck. You can pay the dealer to do this in IDS, or use the latest FORScan build. If you go the FORScan route, access the IPC module and enable Remote Start & Remote Starter Parking Lamps.
5. Activate the remote access module. You can pay your local dealer to do this for you, or most online sellers who sell this module are dealers whom are usually willing to do this for you as part of your purchase. They will activate and generate you a PIN.
You're done. Enjoy your app-based remote start!
If you want to have keyfobs, you'll need to purchase the remote start antenna and keyfob.
A2C9-103170-2. Keyfob with remote start and tailgate release.
DA8Z-15603-A 2015-2017 Remote Start Antenna. (Plz verify at time of order)
I have not added the keyfob-based remote start. I'm more than happy to use the Ford Remote Access iPhone app as I have for the past 4 years.
Good luck!
Good luck!
If I make this (or any other changes) in FORScan will the dealer mess that up down the road when they service the truck or when they update the software?
Is me changing things in FORScan like the old tuners where it has to be changed back to stock before taking the truck into service? Sorry for the lame questions if this is common knowledge.
I don't think you have any reason to worry about the dealer wiping out the changes. As a worst case, should a module fail and have to be replaced, you would have to go back into FORScan and re-enable remote start. Chances are even in that case the dealer will see that you have a remote start module and enable it for you.
Got2haveit I understand and kind of agree with you but $50 per year is really not much to have the convenience of this (OEM parts) system. Years ago I had an aftermarket alarm installed on a pickup truck by a supposedly reputable installer and they messed the electrical system up so bad I promised myself I would never let anybody tap into an electrical system for any reason ever again.
I ordered the two parts that Steve listed from Banner and am going to hopefully get it all set up via FORScan.
I will report back with my results.
Here is another option I found. Plug and play and you rent their programmer for $50 to add the remote start settings into your instrument cluster settings. I'm sure forescan may be able to do this as well.
I do like the idea of being able to start it with three clicks on my existing fob, as well as being able to disable the horn honking which would not make my wife or my neighbors happy when I leave for work in the mornings. I wish I could have found more reviews on this system from actual users.
I then went in through FORScan and enabled the remote start system. I checked the trucks dash menu and figured out I was missing the climate control option, so I went back in and also enabled as many options that were pertainable to my truck. All the options are now there in my trucks menu.
I just need Bobby to activate my module and give me a pin to get it working!
