Coolant question
Old Jul 29, 2017 | 06:39 PM
Bohen's Avatar
Bohen
Coolant question
So I typed in coolant I also typed in Motorcraft coolant and compatibility apparently I'm typing in the wrong things in the search so please forgive me. That being said I have a 2015 F350 6.7 liter my question is it has the factory coolant in it as of now which I believe is the orange what is compatible to use with this the dealer wants 23 bucks per gallon I want to know if I go to the auto parts store up the road what to ask for or look for help me out I got a road trip out to Colorado this Friday there are no issues with the truck no leaks no nothing but just in case it doesn't hurt thank you?
Old Jul 29, 2017 | 07:26 PM
Tedster9's Avatar
Tedster9
Coolant at 2 years I wouldn't be concerned.
Old Jul 30, 2017 | 10:00 AM
Just Strokin's Avatar
Just Strokin
The orange coolant is basically DEXcool. Motorcraft is going to cost more at the dealer. Some part houses may stock it. When I plan on changing mine it will bee a coolant that meets the Ford/DEXcool specs. Probably use Preston or DEXcool or maybe Wal Mart if it states the Ford spec on the bottle.
Meets or exceeds the requirements of WSS-M97B44-D, GMW 3420 (superseded GM 6277M) and ASTM D 3306...DEXcool.
https://www.fcsdchemicalsandlubrican...ing%20Products
Old Jul 31, 2017 | 11:28 AM
smoky_diesel's Avatar
smoky_diesel
VC-3
Amazon, available with same day delivery. $32, or $21 for 50/50
Amazon Amazon
Old Aug 8, 2017 | 10:30 AM
Overkill2's Avatar
Overkill2
I was going to revive the old thread that linked here so instead...Not trying to hijack this thread, but since it's about coolant and I have a coolant question...here goes:
I found an old thread here when I searched for 6.7 coolant and vloney said this:
"The correct stuff has to use OAT (organic acid technology). The way it was described to me, is the OAT actually "eats" into the coolant passages, eventually forming a coating that prevents the "sand leaching" that we're all familiar with."
Does anyone have knowledge about this idea? and if so, is that why not many use a coolant filter on their 6.7s?
I have also been searching for a test strip kit for our engines online and it seems all I find are the big kits instead of smaller ones. Does anyone have a good source for these kits? Thanks..
Old Aug 8, 2017 | 11:57 AM
Just Strokin
Acustrip
2 tests
ACU-4048 Series
10 tests
ACUSTRIP ACU-R071 Series
Nitrite test strips are the same as one used for the 7.3 coolant system. You are only testing the absence of nitrites. The other parts of the strip are not used.
NAPA sells them as does IH/Navistar at Fleetgard
Old Aug 8, 2017 | 02:29 PM
Overkill2's Avatar
Overkill2
Thanks, Larry. Appreciate that...
Old Aug 16, 2017 | 09:44 AM
Batman7777's Avatar
Batman7777
Many already know this but, below is some additional information on another thread.
There are additional precautions and things you must know about the two cooling systems found in the 6.7.
https://www.ford-trucks.com/forums/1...s-warning.html
bedwards
2015 - 2020 F150
Dec 9, 2018 06:03 PM
carolinadingo
Jul 21, 2014 06:52 AM
calf roper
20
Jul 2, 2009 10:15 PM
Mtn Folk
Dec 6, 2007 05:18 PM
Lushman
Apr 8, 2006 10:17 AM
