coolant question
Old Dec 6, 2018 | 06:49 PM
bedwards's Avatar
bedwards
coolant question
Had to help my son with his 2012 F150. The truck called for Motorcraft Orange which I have read is Motorcraft version of Dex Cool? We couldn't find Motorcraft Orange so in a pinch, we put Zerex G-05 in it.
My 2018 has pink coolant in it. What will mix with it? Is there one that will mix with the two? I have used the Zerex G-05 for years, even in my diesel with good results and really don't want to have to keep 2 or 3 different kinds.
thanks in advance
Old Dec 6, 2018 | 08:26 PM
MBuckholz's Avatar
MBuckholz
Oops you made a mistake. Both your vehicles run Dex-Cool. Sometimes it looks orange, sometimes it looks orange/pink in the Fords. The G-05 Gold coolant will screw up the chemistry. Ford has made, likely, a final change in late 2018/2019 to what I call Dew Yellow DY coolant. This is a phosphated OAT coolant. Possibly similar to what Toyota has been using for a while. It is good for 200,000 miles as an original fill. Your son's coolant now only has maybe a 30,000 mile life until you change it since the chemistry's are screwed up. The dew yellow coolant is different than the g05 gold coolant
Old Dec 6, 2018 | 08:34 PM
bedwards's Avatar
bedwards
I just love flushing coolant
Old Dec 6, 2018 | 08:35 PM
MBuckholz's Avatar
MBuckholz
. Hahaha, everybody's got to have a hobby! 😀
Old Dec 6, 2018 | 08:39 PM
MBuckholz's Avatar
MBuckholz
Hope this helps.
Old Dec 6, 2018 | 08:41 PM
MBuckholz's Avatar
MBuckholz
My stupid phone won't upload the coolant chart but here is the link
https://www.fcsdchemicalsandlubricants.com/main/quickref/coolantsEN.pdf&ved=2ahUKEwi7yoT-2YzfAhUF0KwKHVudBxwQFjASegQIBBAB&usg=AOvVaw2UIgJdu mPgqmLn3FeXKRY_
Old Dec 6, 2018 | 08:49 PM
bedwards's Avatar
bedwards
thanks for the quick answer
Old Dec 7, 2018 | 07:18 AM
GABAR's Avatar
GABAR
thanks in advance
Most if not all Ford/Lincoln dealerships will have the recommended Motorcraft coolant in stock in their parts department or you can order it online from various sources if you can wait a few days for delivery.
Old Dec 7, 2018 | 12:43 PM
ford390gashog's Avatar
ford390gashog
Yeah G05 which is a HOAT coolant doesn't mix well with dexcool which is a OAT coolant. The 2012 and your truck both take specialty orange which is also known as dexcool.
Old Dec 8, 2018 | 07:45 AM
smokewagun's Avatar
smokewagun
Hmmmm. The Peak coolant I bought says it's acceptable to mix for ALL types of coolants. I used it in my 2008 Expedition and my sons 2011 F150. Guess I'd better re-read and see if they'll be paying for flushes and new coolant. 😜
It says, and I quote, "Coolants feature a LONG LIFE® coolant technology that is compatible for use in all automobiles and light-duty trucks, regardless of make, model, year or original antifreeze color".
Old Dec 9, 2018 | 03:31 PM
GABAR's Avatar
GABAR
Better to trust the owners manual instead of what`s written on a bottle unless the manufacturer agrees with said bottle. Very easy way for a warranty to be denied.
Old Dec 9, 2018 | 05:58 PM
scott91370's Avatar
scott91370
From the bottle and what you typed are two different things. The bottle part of what you put does not say it can be mixed. I suppose it could be read into it but I don't take it that way.
Old Dec 9, 2018 | 06:03 PM
smokewagun's Avatar
smokewagun
On both vehicles, the warranties have long expired. I'm not concerned after adding 2-3 pints to the reservoir. In a couple weeks when I can schedule the appointments, I'll get them in to replace the coolant. They are both due, and it's too cold here.
Milwaukee1979F150
Jul 6, 2012 08:27 AM
V10Train
May 19, 2012 03:57 AM
Saxon
Aug 6, 2004 11:15 PM
fhartell
Jan 1, 2004 06:44 AM
haakeye50
Jan 5, 2003 08:43 AM
