Driver Door Squeak
Old Nov 14, 2017 | 09:48 AM
  #46
FishRanger's Avatar
FishRanger
I loosened the door latch on the pillar and was able to move it back maybe an eighth of an inch. It pulls the door in some making it not quite flush with the rear door but not noticeable. The squeak, rattle and door movement are gone. So far after about 2500 miles no problems and no squeaks, rattles or door movement. We put about 2K on it pulling our fifth wheel which exaggerates the bumps somewhat and it has held tight.
Old Nov 14, 2017 | 10:03 AM
  #47
Rockinfigs's Avatar
Rockinfigs
I didn't even think about that.. Funny cuz I checked my driver door n its not flush.. It sticks out tiny tiny bit so that might be the problem.. I'm gona loosen the latch n take it in which will make my door flush n hopefully get rid of the squeak
Old Nov 14, 2017 | 10:08 AM
  #48
DSLTRK60's Avatar
DSLTRK60
I can help.
It's not the seals, not the hinges; doesn't need another dousing of silicone either...
It's the door latch and striker. The striker has a super thin layer of plastic coating that wears quickly. The door latch has plastic coating the steel pawl.
Plastic on plastic equals squeaks over bumps, even minute movements will squeak.
Adjusting the striker in will only cause door misalignment and accelerated wear on latch.
Adding stiffer weather stripping will only make door harder to close and accelerate wear on latch.
My solution costs about 1 cent and 30 seconds. Clean the striker with alcohol. Get 3M cloth gaffers tape (or similar) and wrap 1-2 layers of it around striker. Make sure the tape has full adhesion and no ripples. It is best you leave the tape seam toward the outside.
Close door to check function, it should close just like the factory intended it to.
The squeaks should be gone. The fiber in the tape should last for a few months before replacement.
Old Nov 14, 2017 | 10:43 AM
  #49
spongecop's Avatar
spongecop
Semper Fi
i had mine in for a rattle and squeak by interior door handle, drivers side. Tech "insulated" the backside of the panel and it seems to have done the trick.
Old Nov 14, 2017 | 12:08 PM
  #50
shizzu's Avatar
shizzu
I took my truck back to ford a couple weeks ago to tell the mechanic that the door was noisier than before the prior adjustment. met the mechanic as he was parking my truck outside and he stated that on some trucks the door is sprung and needs adjustment.... I can only assume his adjustment was some kind of 'bending' of the door..... =(
Old Nov 14, 2017 | 01:02 PM
  #51
TheLex's Avatar
TheLex
My truck has had a driver's side door shimmy since new. IOW I can hear it flexing around in the frame of the truck as I drive down the road. It also has wind noise on the highway so my guess is the door is not aligned correctly
Old Nov 14, 2017 | 01:46 PM
  #52
daniel044's Avatar
daniel044
i now have this "squeek/rattle" started after a weekend at the ranch. Now it wont go away unless I hold the door with force. Its driving me bananas! Going to try to figure it out today.
Old Nov 17, 2017 | 12:11 PM
  #53
Rockinfigs's Avatar
Rockinfigs
Ok i think i got a fix for the driver door squeak/tick ..I originally thought about adjusting the striker in more so the door would close tighter. But instead of doing that i put some electrical tape over the striker where the door latch goes over and it seems like it fixed the problem.. Trust me im not happy with putting electrical tape on the striker on a $70k truck to fix a door squeak/tick i shoudlnt have to..anyways its fixed and il keep it like that until i hear the noise again.
Old Nov 17, 2017 | 12:20 PM
  #54
spongecop's Avatar
spongecop
Semper Fi
Originally Posted by DSLTRK60
I can help.
can you post a picture or link to this tape please?
Old Nov 18, 2017 | 08:31 AM
  #55
daniel044's Avatar
daniel044
will try this today and see how it works. Thanks for the info
Old Nov 18, 2017 | 11:05 AM
  #56
DSLTRK60's Avatar
DSLTRK60
It's a cloth tape, easy to tear side ways, but very hard to tear linearly. I cut a small strip about .75" wide and 1'' long and you can barely see it on the striker, even if you are looking for it.
I tried electrical tape, the nylon is too soft to stand up to repeated door closures and it left a sticky residue upon removal.
Old Nov 18, 2017 | 11:12 AM
  #57
Timberwolf2017's Avatar
Timberwolf2017
Yep, that stuff is almost $50 a roll on Amazon
Old Nov 18, 2017 | 11:24 AM
  #58
Rockinfigs's Avatar
Rockinfigs
Yeah exactly.. That stuff is not cheap.. Il stick w my $1 electrical tape.. Works fine.
Old Nov 18, 2017 | 11:39 AM
  #59
DSLTRK60's Avatar
DSLTRK60
$50 bucks? wow, I bought a roll for $8.50 on eBay.
Old Nov 18, 2017 | 03:14 PM
  #60
Rockinfigs's Avatar
Rockinfigs
Cheapest 3m gaffer tape on ebay is $23
