E4od not shifting
Old Nov 11, 2023 | 08:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it could. If the PCM thinks that the transfer case is in 4x4 low the shifts will be extremely early.
Old Nov 11, 2023 | 08:54 PM
Shadetreejunkie's Avatar
Shadetreejunkie
Any way to test this? the 4x4 and 4x4 low lights aren’t lit up on dash.
Old Nov 12, 2023 | 07:50 AM
Mark Kovalsky
Check the wire from the transfer case to the PCM for short to ground and short to power. If I had a wiring diagram I could tell you which pin it is, but I do not have one.
Old Nov 12, 2023 | 07:56 AM
Shadetreejunkie
I will try to track one down thank you for the help!
Old Nov 13, 2023 | 06:08 AM
JWA's Avatar
JWA
There are several listed for sale on eBay but typical for that year and Series they're a bit pricey but authentic Ford stuff, one example: 1997 F-250 EVTM
One more: 2nd 1997 F-250 EVTM
Old Nov 13, 2023 | 12:49 PM
Shadetreejunkie
I found a pretty good site with all the info I need and it has some diagnostic procedures also. All data.com. Looks like I’m gonna need a breakout box to track track down the exact problem.
Zapp911
Oct 11, 2022 03:32 PM
justcruzin125
Apr 8, 2018 09:50 PM
aclaybor
Feb 3, 2017 01:32 PM
Destefano07
Sep 5, 2012 10:14 AM
Biglame
Nov 7, 2008 08:32 PM
