It has been awhile since I have visited these forums, but I am in desperate need of assistance. Yesterday, while riding on the highway, I went to accelerate and my truck down-shifted rather harshly. Afterwards, my truck proceeded to stall, so I pulled over on the side of the road. I managed to get the truck restarted and it seemed to idle fine; my check engine light came on though. Trying to put the truck into either drive or reverse resulted in a bang, and accelerating causes the truck to shift extremely hard. Getting it towed back to the house was my only option. It also wants to stall intermittently when I try to put it into gear.
I have attempted to pull codes for my truck, and I came up with: 26 and 126
From what I have read, 126 indicates a bad MAP sensor, and 26 could indicate MAF sensor being out of range. These may affect how the engines runs, but would either affect how the transmission operates?
I am hoping that someone has some advice that they could offer, because at this time, my vehicle is not drivable; I depend on it to get to work, as I know most of you do with your vehicles. I do most all of the maintenance on my truck myself, and don't have a problem getting my hands dirty. However, this is an issue that I do not know how to readily solve. Any assistance would be greatly appreciated.
Is there any way for my truck to tell exactly which of the two I should be pulling? Noted. I will have to go back out there and try to read them again.
I went ahead and warmed the engine and pulled the codes again. The only code that appeared was 126.
I found a broken vacuum line that I fixed. I was able to drive my truck a few miles to warm the engine. The only symptom that I am experiencing is extremely hard shifts. It does go through every gear however.
126 indicates a MAP/BARO sensor being out of range. These may affect how the engines runs, but would either affect how the transmission operates?
This is most likely your problem, the computer is programmed to switch to a "safe" strategy when any one of the major sensors develops a fault and part of that strategy is to jack transmission line pressure to maximum which results in very hard shifts. Note.. there is no MAP/Baro sensor on a MAF truck, that info is calculated using MAF sensor data, and that implies that you have a MAF sensor fault.
Thank you everyone for assisting me. My truck is now running as it should. Now if I could only save the money to replace tie rod ends, radius arm bushings, and shocks. lol
One thing about hard shifts on the E4OD: while it's uncomfortable, at least you're not wearing the transmission out. It's probably not generating much heat at all. No; those extra-crisp shifts are hammering on the U-joints and rear gears.
My stupid e4od hard shifted and wouldn't engage 4th... even after a $3200 rebuild. My speedo/PSOM is the culprit... I tested my theory by banging the dash with my fist and now it shifts like normal...
