E4OD problem
Old Aug 19, 2012 | 05:09 PM
Destefano07's Avatar
Destefano07
E4OD problem
I have a 1990 f-250 4x4 7.3, I have replaced the
VSS, the Speed control sensor on the transfer case, the external plug on the passenger side of the transmission and the throttle position sensor, it did get rebuilt at certified transmission about year ago but its not there problem...... Now the problem..... When i am driving from a stop the transmission will shift fine 1,2, when you get into 3rd gear it will consistantly down shift into 2nd and up shift back into 3rd untill you reach the higher rpms of 3rd gear then it will shift into over drive fine. The overdrive lamp is not blinking, my speedometer does bounce a little, its not smooth. It does not bang into reverse or drive, the fluid seems fine. thats about all i can tell thats wrong. please help...
Old Aug 19, 2012 | 06:01 PM
dustybumpers's Avatar
dustybumpers
Check the engine codes, trans codes will show up. It may be the tps needs adjustment, but get the codes first, so you aren't just throwing money at it
Old Aug 19, 2012 | 06:03 PM
Destefano07
thanks , I'll reply back after.
Old Sep 5, 2012 | 10:14 AM
Destefano07
i found the problem, the computer for the transmission had a very loose ground, the one on the inner fender, and also the crazy downshifting was because of the plastic gear in the transfer case
fishfreak101
20
Nov 13, 2023 12:49 PM
1993 f150 4x4
Sep 7, 2016 02:19 PM
96ruby
Jun 29, 2016 10:23 PM
dylan8427
Mar 5, 2009 03:20 PM
larry1211
Oct 5, 2007 11:56 AM
