E150 4 Wheel Disc Brake Conversion
Old Sep 11, 2018 | 11:06 AM
  #61
98Econoline150's Avatar
98Econoline150
Old Sep 11, 2018 | 11:14 AM
  #62
98Econoline150
Only release the springs on the pads after the caliper is together, otherwise the pads will fly out.
Brake hose routing is the same. With a slight tweak the older hoses work with the newer calipers.
All new ball joints on 2005 junkyard knuckles
The original brakes are single piston, here you can see the dual pots of the calipers.
Wheel bearings, washers, spindle nut, lock, and outer seal carry over from 1992-2003 models, inner seal is different.
Old Sep 15, 2018 | 08:46 AM
  #63
98Econoline150
The next part in this series in to set up a working parking brake. I will need to get all new cables and all the parts at each wheel. Most of this is still reality available and I will be looking at the junkyard as well.
Old Nov 21, 2018 | 04:14 PM
  #64
atic's Avatar
atic
Originally Posted by 98Econoline150
I have decided to discontinue updating this, since there seems to be no interest.
Fantastic walk through of all of the work. Appreciate you documenting the process.
Old Nov 27, 2018 | 09:34 AM
  #65
98Econoline150
Thank you. It was quite the journey, but worth it. I would guess I have reduced 60-0 stopping about 40-50 feet over the single piston front discs and rear drums.
Old Nov 30, 2018 | 08:12 PM
  #66
Wopper's Avatar
Wopper
So did you replace the entire rear end, or just make new end mounting plates for the disc setup?
Old Nov 30, 2018 | 08:16 PM
  #67
98Econoline150
The rear end is still an 8.8, but it is a new one with Traction Lok and disc brake mounting flanges.
Old Jan 15, 2019 | 05:57 PM
  #68
DCarrVan's Avatar
DCarrVan
93 e350 .....i wanna do the same upgrade to the Rear of my van ...i would have to recover backin pla
So, I finally got around to moving forward with the brake project. What is going on is I am taking a 98 E150 and installing big brakes on it. This applies to all 1992-2003 E150s.
*THIS IS ONLY FOR 5-LUG WHEELS*
UPDATE
*NOT A DIRECT BOLT-ON*
*REQUIRES 16” WHEELS*
Original brakes are one piston calipers in front, and drums in the rear. These brakes are standard from 1992-2003.
New brakes are Ford brakes for 2004-06 E150s. Front brakes are two piston calipers, and rear are one piston calipers.
The whole rear axle is being replaced so rear brakes are being upgraded. This van has an ABS issue without DTCs so it is better to upgrade.
Benefits:
- More braking power
- Less pedal fade
- Parts have more availability (not as old)
- Ease of service over drums
- Simplicity of disc brakes
The spindles were sandblasted, had new ball joints installed, and then painted semi gloss black.
The painted spindle and rotor shield are back together. The other side is the mirror image.
what Years could i use for.my 93 e350 to change from drum to disc on the rear ?
Old Jan 15, 2019 | 07:28 PM
  #69
98Econoline150
This will work for 1992-2003 E150s
You need either a complete axle from a 2004-2006 E150 van, or the axle ends off of any 2004-2006 E150. The vans (no windows on the sides) use an 8.8 like earlier E150s. Wagons (with windows on the sides) use a Ford built 9.75” axle. So if you opt for the whole axle out of a wagon, you need the propellershaft. You need to take apart the HCU and remove the residual pressure valve or find it if it is elsewhere, otherwise the rear wheels will lock-up, no matter what.
Old Jul 21, 2019 | 12:47 AM
  #70
444whitehorse's Avatar
444whitehorse
You wouldn't happen to have the width handy for the wms to wms of this axle would you? All I can turn up for search is that it's a 9.75 or 8.8 axle, mainly what you just stated. Looking for a viable 5x5.5 bolt pattern disc brake axle to swap under a Ranger, that will match up with what a d44 ttb will be. Between 63 and 68" typically.
Old Jul 15, 2022 | 01:04 PM
  #71
Ggatten's Avatar
Ggatten
4wd Low
Good thread!
Good stuff here, exactly what I was looking for. Couple questions:
I have a 99 E150. For now only interested in front brake upgrade. Will my existing master cylinder be OK, or I need 2004 - 2007? OP got new one, but appears to not use it?
For ABS, do I need different sensors? If so, different connectors too? ECU programming or other stuff? Hoping just plug and play!
Thanks!!!
Old Jul 16, 2022 | 05:56 AM
  #72
JWA's Avatar
JWA
I've done what's generally called the 2008 Front Brake Upgrade for E-250's, not sure if your E-150 is the lighter duty version though. Here's a link to another site I posted a "how to" post that might be helpful: 2008 E-250 Front Brake Upgrade The ABS sensors and master cylinder can remain stock.
Do be advised based upon your chassis GVW rating this upgrade might not work for you.
Old Jul 20, 2022 | 07:15 PM
  #73
Ggatten's Avatar
Ggatten
4wd Low
Thanks. 250s and 2008+ are way different than my old POS. Best I can do is is the 2004 to 2006 upgrade. Unless of course I want to spend gobs of time and money,, which I don't.
Old Nov 24, 2024 | 05:15 AM
  #74
FL-livin's Avatar
FL-livin
1st Gear
thanks for info regardiing brake upgrade. however i do have a question about rear axle. from what Model and years are the new axles from 2004-06? i have 2003 E150 and would like nothing better than to do this upgrade. Any specific info about parts pricing and challenges i should be aware of would be appreciated if you have the time.
Old Nov 24, 2024 | 09:52 AM
  #75
DCarrVan's Avatar
DCarrVan
Unsure the Years U Can Swap . Haven't heard of any one in those years doing swaps . Mostly disc or 4X4 necessity. Ok Sorry i don't have any info really
Luxliner
Jun 10, 2018 03:21 AM
93 Blue Z32(NC)
Large Truck
Nov 19, 2016 08:54 AM
DZL JIM
Jan 30, 2012 08:55 AM
pit_of_pity
Jul 12, 2011 01:53 PM
qwertmonkey
Dec 3, 2010 02:38 PM
