1985 ford f600 gas. Rear axle change or brake conversion
Iv got bad leaky wheel cylinders and wanted to know if theres a rear axle brake conversion or where can i find where and what axle to swap on to this truck to have better brakes
I have lucus gerling brake system
mabe someone know a junk yard or someone that has made a brake kit
? will rear disk brakes stop a heavy load or does rear brakes have to be drum
thanks for any help as I'm slowly learnine on bigger trucks
Just fix what you got. Nothing wrong with Lucas brakes if they are working properly. Second only to air brakes in stopping power in my book. Also, Truck Pro will be your friend on these brakes. I had to replace the manifold that bolts on the master cylinder in my F-800. $950 from ford, $168 from truck pro.
98Econoline150
72
07-20-2022 07:15 PM
Luxliner
06-10-2018 03:21 AM
cutthroatxxx
09-05-2014 03:10 PM
