2000 X Build Thread
Old Aug 22, 2017 | 07:28 PM
  #46
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Update to my MOD list
Originally Posted by Tylus
Drivetrain:
1. Change fluids
2. Muffler delete/straight pipe
3. Leave alone otherwise
Suspension:
1. V codes Front - Done
2. Modded B codes rear - Done
3. 285/75R16 Treadwright Warden AT - Done
4. New shocks - Done
5. Flip sway bar end links/mount - Done
6. Replace Steering stabilizer
7. Replace ball joints (Driver - Done)
Interior:
1. 4x2 Rear Hatch Struts
2. Touchscreen radio with BT/ELM/WIFI
3. 08+ center console...or at least 2002+ console cupholders
4. Maglite mounted by drivers seat - Done
5. 2002+ dash cupholders
Exterior:
1. 2008 Style Tow Mirrors- Done
2. 2006 Style Headlights with DIY Harley Mod
3. 4X4 Sticker - Done
4. Shiny tailpipe
5. Backup Camera
6. 2005+ front conversion. potentially 2008+
7. Tinted Cab lights - Done
8. Marker Lights on running boards
9. F-250 grab handle on drivers pillar - Done
10. Black Door Handles
11. Custom Built Safari style roof rack
12. Black out rims (corroded), but leave caps chrome
Repairs:
1. Replace front axle u-joints - Done
2. Rebuild Auto hubs (currently frozen) - Done
3. small 1/2" spot of rust on both rear doors in window seam
4. Unstick all the power door locks - Done
5. Figure out why the shifter is so stiff and doesn't quite lineup - Done
Old Aug 22, 2017 | 08:18 PM
  #47
WE3ZS's Avatar
WE3ZS
That list is shrinking nicely Tylus, good job so far!
Will you be fabbing/building the custom roof rack or will you have to outsource that job? I don't need and really can't use one but I have always wanted to build a custom roof rack. I have been thinking about fabbing one up for my little Suzuki Vitara but there isn't very much metal up top to mount it to.
Old Aug 22, 2017 | 08:26 PM
  #48
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I have the $100 Walmart roof rack in the garage. It worked, but even on the Tahoe was rather small.
Home Depot has 4' of 1'x1' square tubing for $14
http://www.homedepot.com/p/Everbilt-...1117/204225781
I have a 110v welder. Gotten lots of practice welding on my '86 Bullnose doing rust repair recently.
Found a neat DIY Tutorial where you can use an angle grinder to section the bar just enough to bend. Then you are only welding 1 seam instead of butt welding. The rack is my project after I get done with the X repairs. Going to make sure it also doesn't look ridiculous on the Tahoe, as we may need it for longer trips.
Old Aug 22, 2017 | 08:32 PM
  #49
WE3ZS's Avatar
WE3ZS
Check, and as you well know, photos will be required!
Old Aug 23, 2017 | 05:08 AM
  #50
unleashd's Avatar
unleashd
Seriously, if you are looking for volunteers, count me in I don't have the skills or tools. But I wouldn't mind having to drive up to PA and fund the project
Old Aug 23, 2017 | 05:13 AM
  #51
unleashd's Avatar
unleashd
and as always. the first mod I do to every truck I get
What brackets are those holding the flashlight? Nice and simple mod. My maglite sits in the cubby on the door and keeps rattling every time I close the door. Drives me nuts
Old Aug 23, 2017 | 09:23 AM
  #52
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Maglite Mount
Mag Flashlight Bracket Mounting Clip D Cell Maglight Snap Clamp Holder 2 PC Pack
although I think I paid like $5. I put them in all my rigs
Old Aug 23, 2017 | 06:31 PM
  #53
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Fixed the Rear Defogger today.
Comes with all this cool stuff. activator, alcohol wipe, sandpaper, copper paint, a stencil, and conductive paste
I went a little overzealous with the sandpaper
The old tab re-epoxied on
and then just to make sure I had good electrical contact everywhere, I liberally used the copper paint
hard to see, but I did resistance checks and got 0.5 ohms. contact to contact on multimeter was 0.5 ohms...so I think I got a good connection lol
doesn't look to terrible. even with all my overkill on the copper paint
Old Aug 23, 2017 | 10:00 PM
  #54
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Looks good to me. Nobody will ever know.
What size u bolts did you go with on your modded-B codes?
Old Aug 24, 2017 | 05:22 AM
  #55
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Tuff Country #27955
https://www.summitracing.com/parts/tfy-27955
17" long, but only 2" are usefully threaded after I cut them down so a socket would fit for torquing. Stupid long for X application. I bought based on fitting a F-250. Whoops
Ended up threading 2" additional onto them. Would not recommend for X use
Old Aug 28, 2017 | 09:31 PM
  #56
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Replaced my rotted out shackles with 1" lift shackles
That sucked. Had forgotten how bad a job it was to perform. Ended up removing the axle from truck. Couldnt get things aligned until I went to ground zero. Will snap pics in daylight
Old Aug 28, 2017 | 09:36 PM
  #57
thor363's Avatar
thor363
What's the reason for: 5. Flip sway bar end links/mount
Old Aug 28, 2017 | 09:42 PM
  #58
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Depending on the amount of lift, the factory mount location will interfere with leafs.
I have lifted 4" from stock and now have to flip the mount.
here is a picture of my last X where I flipped it. The mount is normally bolted inside the frame rail. Just unbolt and put on bottom of frame rail. Then use like normal.
Old Aug 28, 2017 | 10:41 PM
  #59
thor363's Avatar
thor363
Thanks. Rep previously sent or I'd rep u again
Old Aug 28, 2017 | 11:48 PM
  #60
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
That is a great tip right there. Thanks, Tylus.
