Duraspark ii conversion question
Old 06-12-2017, 03:24 PM
Gunnerboy's Avatar
Gunnerboy
Gunnerboy is offline
I know there are lots of threads on this but im not seeing any with a plug like what i got...wiring harness, ignition module, and coil all came off a 79 f150, the plug i have in my hand in the picture where does that plug into?? You can see the plugs to the right are all i have left from the factory wiring when i removed the TFI crap. Also how to i hook up the ignition system?
Old 06-12-2017, 04:00 PM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is offline
Old 06-12-2017, 04:07 PM
Gunnerboy's Avatar
Gunnerboy
I have a Vaccum advance distributor made for this harness does that still apply?
Old 06-12-2017, 09:32 PM
No - I can't help you there.
Old 06-13-2017, 01:00 PM
Wagonboy's Avatar
Wagonboy
Wagonboy is offline
You need the distributor or MAYBE just the pick-up coil to match the ing module.
Old 06-13-2017, 02:40 PM
Gunnerboy's Avatar
Gunnerboy
I got both of those I'm just baffled by the square gray plug
Old 06-13-2017, 04:04 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
I've never seen the square gray plug before. What year / engine combo did you get the wiring harness from?
Old 06-13-2017, 07:13 PM
Gunnerboy's Avatar
Gunnerboy
78/79 F150 or 250 didnt pay enough attention all i know is it was a 360/390 engine the harness was off of...My luck to find the odd duck
Old 06-14-2017, 12:20 PM
AbandonedBronco
Well, should it come down to it, it is available:
Ford Duraspark Ignition Harness We Make Wiring THAT Easy!
Old 06-14-2017, 01:10 PM
TheDudeAbides's Avatar
TheDudeAbides
TheDudeAbides is offline
I don't mind doing my own wiring, but its good to know there's an "off-the-shelf" harness to be had out there. Thanks for the link.
Old 06-14-2017, 06:54 PM
ShakinBacon's Avatar
ShakinBacon
ShakinBacon is offline
The square plug has the oil pressure, water temp, and I think the + side of the coil. In 1980 they went to a round plug, probably the one that is above your hand, just have to figure out which wire does what and splice things together. If you still have the wires that came out of the truck, should be able to find the other half of the round plug and use it.
68cabby
33
09-08-2014 11:34 AM
4wheeltank
10-11-2005 05:19 PM
quentinorciuch
01-01-2004 02:38 AM
quentinorciuch
Electrical Systems/Wiring
12-31-2003 12:08 PM
Chuck 6083
1966 - 1977 Early Broncos
12-16-2002 04:07 PM
Quick Reply: Duraspark ii conversion question
