Duraspark ii conversion question
Old Jun 12, 2017 | 03:24 PM
Gunnerboy's Avatar
Gunnerboy
I know there are lots of threads on this but im not seeing any with a plug like what i got...wiring harness, ignition module, and coil all came off a 79 f150, the plug i have in my hand in the picture where does that plug into?? You can see the plugs to the right are all i have left from the factory wiring when i removed the TFI crap. Also how to i hook up the ignition system?
Old Jun 12, 2017 | 04:00 PM
The Frenchtown Flyer's Avatar
Old Jun 12, 2017 | 04:07 PM
Gunnerboy's Avatar
Gunnerboy
I have a Vaccum advance distributor made for this harness does that still apply?
Old Jun 12, 2017 | 09:32 PM
No - I can't help you there.
Old Jun 13, 2017 | 01:00 PM
Wagonboy's Avatar
Wagonboy
You need the distributor or MAYBE just the pick-up coil to match the ing module.
Old Jun 13, 2017 | 02:40 PM
Gunnerboy's Avatar
Gunnerboy
I got both of those I'm just baffled by the square gray plug
Old Jun 13, 2017 | 04:04 PM
AbandonedBronco's Avatar
AbandonedBronco
I've never seen the square gray plug before. What year / engine combo did you get the wiring harness from?
Old Jun 13, 2017 | 07:13 PM
Gunnerboy's Avatar
Gunnerboy
78/79 F150 or 250 didnt pay enough attention all i know is it was a 360/390 engine the harness was off of...My luck to find the odd duck
Old Jun 14, 2017 | 12:20 PM
AbandonedBronco
Well, should it come down to it, it is available:
Ford Duraspark Ignition Harness We Make Wiring THAT Easy!
Old Jun 14, 2017 | 01:10 PM
TheDudeAbides's Avatar
TheDudeAbides
I don't mind doing my own wiring, but its good to know there's an "off-the-shelf" harness to be had out there. Thanks for the link.
Old Jun 14, 2017 | 06:54 PM
ShakinBacon's Avatar
ShakinBacon
The square plug has the oil pressure, water temp, and I think the + side of the coil. In 1980 they went to a round plug, probably the one that is above your hand, just have to figure out which wire does what and splice things together. If you still have the wires that came out of the truck, should be able to find the other half of the round plug and use it.
68cabby
33
Sep 8, 2014 11:34 AM
4wheeltank
Oct 11, 2005 05:19 PM
quentinorciuch
Jan 1, 2004 02:38 AM
quentinorciuch
Electrical Systems/Wiring
Dec 31, 2003 12:08 PM
Chuck 6083
1966 - 1977 Early Broncos
Dec 16, 2002 04:07 PM
