Sponsored by: Halo Lifts
Truck thinks trailer is connected
Old 05-08-2017, 10:40 PM
DavidK2017's Avatar
DavidK2017
DavidK2017 is offline
Good evening,
We just got our new trailer got it all setup got our back up assist setup. Now everytime I start the truck it reverts to the trailer towing info screen vs the trip/fuel it did before. This even happens when the trailer is not connected. Do I have a setting wrong or somthing?
Thanks
Old 05-08-2017, 10:50 PM
DavidK2017's Avatar
DavidK2017
All good, after posting my google fu started working found the answer. Had to set it to no active trailer.
Old 05-09-2017, 07:10 AM
Terryd91's Avatar
Terryd91
Terryd91 is offline
Don't feel bad I did the same thing lol. It was driving me crazy for 3 days before i realized you had to set it back to no trailer.
Old 05-09-2017, 08:22 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Me too. I think it is an easy trap to fall into.
Old 05-09-2017, 03:49 PM
CR172's Avatar
CR172
CR172 is offline
Hmmmm. Whenever I disconnect my trailer and harness, it goes back to nothing all by itself...
Old 05-09-2017, 04:13 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Maybe they changed the newer MY? Mine's a 2015.
Old 05-09-2017, 04:29 PM
CR172's Avatar
CR172
CR172 is offline
So is mine. 2015 XLT Scab, 5.0L, 6.5ft bed
Old 05-09-2017, 07:42 PM
cjcocn's Avatar
cjcocn
cjcocn is offline
Mine is a 2015 and reverts back on its own also.
Old 05-10-2017, 07:50 AM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
Mine's a 2016 and it reverts back once the trailer is disconnected. I did have the trailer connected issue on my 2012 F150. It was always after towing the car hauler, never with any other trailer.
Old 05-10-2017, 07:59 AM
Terryd91's Avatar
Terryd91
Terryd91 is offline
Mine did it when i was screwing around with setting and set up both of my trailers with out them connected. I didn't know you had to set it back to no trailer. But for fun i hooked up my utility trailer and it went to the default trailer, and when when i unplugged it, it went back to normal. All my trailers are 7 pin becuase i don't like adapters and that's all my jeep had lol.
I would try hooking it back up, let it prompt you for the trailer then disconnect it. It seems like if you manually set it it will stick but if the truck auto detects it then it will go away on its own. I need to set up my camper tonight so i will mess with it some more.
Old 05-11-2017, 02:01 PM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
My '15 did not revert back to no active trailer but my '17 does. However the '17 brings back the trailer screen on the menu the next time you start it up even without a trailer connected
Old 05-11-2017, 02:14 PM
Terryd91's Avatar
Terryd91
Terryd91 is offline
if you change active trailer back to none it should stop, mine was doing the same thing.
srkr
2017+ Super Duty
15
04-26-2024 01:07 PM
Flathead2755
2017+ Super Duty
07-06-2023 09:07 AM
Stephen C
2015 - 2020 F150
04-12-2019 06:31 PM
baronmic1
2015 - 2020 F150
01-09-2017 12:31 PM
wb6anp
2017+ Super Duty
10-11-2016 08:49 PM
Quick Reply: Truck thinks trailer is connected
