No conventional trailer stored???
Old Dec 10, 2017 | 09:26 PM
srkr's Avatar
srkr
I have saved my trailer and named it..every time I pick my trailer and go to options and try and activate my blind spot I get the error “ No Conventional Trailer stored”
Any ideas? Am I doing some thing wrong.
Old Dec 11, 2017 | 10:18 AM
giant futon's Avatar
giant futon
When you are trying to select it, is your trailer connected or disconnected? I had more success with this when the trailer is connected. If that doesn’t work, then cycle the ignition on then off with trailer connected and see if it recognizes it then.
GF
Old Dec 11, 2017 | 11:03 AM
brady420's Avatar
brady420
I get the same thing...no matter what I do I see 'no conventional trailer'. I hope someone can provide some insight here.
Old Dec 11, 2017 | 11:34 AM
jeffba's Avatar
jeffba
Can you go in and edit your saved trailer?
Old Dec 11, 2017 | 08:28 PM
klassic's Avatar
klassic
Me too.. no conventional trailer. BLIS goes off.
Old Dec 11, 2017 | 08:59 PM
srkr's Avatar
srkr
Still looking for help.
mhoefer's Avatar
mhoefer
It only allow you to edit a trailer when connected, and then to select it must be less than 27 feet in order to have BLIS. It also must be a conventional trailer.
Old Dec 11, 2017 | 09:03 PM
wb6anp's Avatar
wb6anp
Go into your basic, non trailer settings, and make sure the blis for trailer is checked, Ill go to my truck and get better, info and a picture in a minute. Took me a while to figure that out, fund it with help from some one here. It some how gets unchecked.
Old Dec 12, 2017 | 05:09 AM
porthole's Avatar
porthole
Do you have trailer brakes?
Old Dec 12, 2017 | 06:41 AM
srkr's Avatar
srkr
Yes I do have trailer brakes. 2010 Airstream.
Old Dec 13, 2017 | 08:36 AM
brady420's Avatar
brady420
Ahh....so it's tied to BLIS for trailer being selected?? During trailer setup, it asks the length of trailer and anything over 32'(?) feet automatically turns off BLIS. That must be the problem because my TT is 35'...I get all the way through set up and then nothing other than the 'no convetional trailer' message.
Now...I wonder how poorly the system works if I override the trailer BLIS to be on by starting my trailer is only 32'? All other measurements seem to work fine. Note that I would likely only 'trick' the system to confirm this is the problem.
My trailer is now in winter storage so I won't know until early next year.
Old Mar 28, 2018 | 09:39 PM
kswrmk's Avatar
kswrmk
I had the same issue tonight when connecting my conventional pull dump trailer. This worked for me. Thanks wb6anp!
Old Jun 4, 2018 | 01:29 PM
Stanbro's Avatar
Stanbro
That worked for me too. I greatly appreciate your input on this.
Old May 7, 2020 | 08:02 AM
wreckerboy's Avatar
wreckerboy
Posted in wrong thread.
Last edited by wreckerboy; May 7, 2020 at 08:07 AM. Reason: Posted in wrong thread
Old Oct 16, 2022 | 05:58 PM
52Flthed's Avatar
52Flthed
posted in wrong thread
