The Super Duty owner's manual has a long section on placing and using the stickers. They are obviously only useful on tag trailers. I'm assuming there will be a sticker or two in the owner packet somewhere. Probably available at the parts dept too.
On the trailer display, when you are setting up a new trailer can you add the trailers current milage or edit the milage.
No you are stuck with starting over. I have mentioned before I use this to track when to grease the wheel bearings and every time I change trucks loose my data.
I also loose all of my saved "favorite" songs and station numbers in Sirius. To bad you can't download that data and then reload it to the new vehicle.
Also remember that when you unplug the trailer's connector you still have to manually go and select "no active trailer" or the stupid system will keep putting miles on your trailer that is no longer connected.
I guess its a good thing I put this on my Trailer, RV SOLUTIONS they will set your current milage, they also set your tire size for rotations.
