LED Lights??
Old Aug 22, 2017 | 10:06 PM
  #196
Bullrdr82's Avatar
Bullrdr82
I still can't get my drivers side factory bulbs loose .... I can't get in to the bolts hidden by the bumper to pull housings. Only way I see is dropping the front bumper....
Any suggestions?
Old Aug 22, 2017 | 10:52 PM
  #197
k7lvo's Avatar
k7lvo
Any suggestions?
I had to actually work a pair of channel locks in there and GENTLY twist them loose. Once they pop loose, they come out easy. There must be some kind of coating on the mating surfaces that acts like glue when it dries.
Old Aug 23, 2017 | 05:18 AM
  #198
LiquidSteam's Avatar
LiquidSteam
I removed the windshield washer funnel as Hackenbush advised and then lightly grabbed the bulb housing with a long set of needle nose pliers. Just an 1/8 turn to loosen and then popped out east by hand.
Old Aug 24, 2017 | 08:04 PM
  #199
LiquidSteam
Done
Old Aug 25, 2017 | 06:59 AM
  #200
CO Wapiti's Avatar
CO Wapiti
Liquid Steam, Can you post a picture of both your low beams and high beams on a wall or your garage door about 30 feet away so we can see what kind of pattern the Auxbeams throw out. It would be much appreciated.
Old Aug 25, 2017 | 09:46 AM
  #201
LiquidSteam
I can try to do something. My driveway is a hill so I can get any distance away and still be flat.
Old Oct 29, 2017 | 01:30 PM
  #202
gumby223's Avatar
gumby223
Trailering
Originally Posted by CopperCore
Here's what I ordered:
Front blinkers-
JDM ASTAR Extremely Bright PX Chipsets 7440 7441 7443 7444 LED Bulbs ,Amber Yellow
Sold by: JDM ASTAR
$24.99
License plate and front markers - (with lots of replacements)
EverBright 20-Pack White T10 194 168 2825 W5W 5050 5 SMD LED Bulb For Car Replacement Interior Lights Clearance Wedge Dome Trunk Dashboard Bulb License Plate Light Lamp DC 12V
Sold by: EverBright Leds
$8.99
Backup lights -
Partsam 1Pair 7443 W21W Projector Led Bulbs for Backup Reverse Light Aluminum 33-Epistar-5730-SMD White Car Led
Sold by: partsam
$9.99
All 3157 bulbs - rear brake and blinkers
Yorkim Extremely Bright 18 Chipsets 3056 3156 3057 3157 18-SMD 5050 Wedge LED Bulbs for Backup Reverse Lights ,12V Brake Light, Parking Light,3157 LED Bulb (Pack of 10)
Sold by: Yorkim
$25.99
Fog lights -
SiriusLED 9005 9145 H10 Size Projection LED Super Bright 30W 6000K White Fog Light DRL Bulb Pack of 2
Sold by: SiriusLED
$24.95
Front headlights -
2 of Auxbeam F-S3 Series H13 LED Headlight Bulbs Conversion Kits with 2 Pcs of Headlight Bulbs 72W 8000LM PHILIPS CSP Chips
Sold by: Auxbeam
$45.99
Had to Forscan to get rid of the hyperflash for rear LED bulbs, but worth it not to have to wire in some canceller, front LED blinkers worked fine as well.
CopperCore,
Looks like you've already went down the road I'm heading down, changing incandescent bulbs to LED. I've already changed a few, and plan to change a few more. I'm currently looking for a LED replacement for the brake/tail light bulbs. I was thinking about getting the JDMaster ones. I see that you put them in the front turn signals on your truck. What are your thoughts on those bulbs? What about the Yorkim bulbs you put in your tail lights, how do you like them? Same as stock? better? Also, I was wondering if you could post a picture or video of them during the day and/or night for reference. Any help you can offer would be appreciated. Thanks
Old Nov 8, 2017 | 10:47 PM
  #203
Cabindweller's Avatar
Cabindweller
Any update from the folks running Auxbeams? Are they still functioning properly? The reviews seem to be all over the map here.
Old Jan 25, 2018 | 11:45 PM
  #204
mikemorales's Avatar
mikemorales
Originally Posted by Hackenbush
What the dealer does has nothing to do with the headlights. All they do is turn off the bulb out warning, That way it ignores the low voltage the Turn signals/Brake lights would trigger. All other lights you can change at anytime without issue, Including Head Lights Fog Lights.
Hate to bring up an old thread but this comment caught my interest. When the dealer disabled this warning, does this eliminate the need for resistors on the brakes and flashers?
Old Jan 26, 2018 | 12:02 AM
  #205
motoxxxloak's Avatar
motoxxxloak
I’m running these and I hate them more and more. Love to color and the output but the beams are terrible. Not matter how I rotate this 3 sided POS, I cannot get a solid light pattern that isn’t all over the place. Will definitely be getting new ones after I read thru this thread
Old Jan 26, 2018 | 05:55 AM
  #206
Poncho450's Avatar
Poncho450
Originally Posted by motoxxxloak
I’m running these and I hate them more and more. Love to color and the output but the beams are terrible. Not matter how I rotate this 3 sided POS, I cannot get a solid light pattern that isn’t all over the place. Will definitely be getting new ones after I read thru this thread.
There's a lengthy thread on this, so I'll leave links to the topic and the lights we used. A little over month so far and I like them.
But keep in mind that this all very subjective.
https://www.ford-trucks.com/forums/1...dlights-7.html
Amazon Amazon
Old Jan 26, 2018 | 07:30 AM
  #207
MNSuper's Avatar
MNSuper
Correct. I had this done and switched to LED front signals. No resistors needed.
Old Jan 26, 2018 | 08:56 AM
  #208
user 474747383's Avatar
user 474747383
Old Jan 26, 2018 | 09:41 AM
  #209
Mississippi8's Avatar
Mississippi8
Im just curious why yall keep ordering Auxbeam?? Cutting on and off,beam pattern isnt right no different in high and low beams...If they are giving yall that much trouble from the start do u really think they gonna last a few yrs??
Old Jan 26, 2018 | 01:14 PM
  #210
mikemorales
This completely just blew my mind, now I must speak with my dealership to see if they can do this for me. If there a thread with more info, please point me in the right direction. Thanks for the info everyone.
