Sponsored by: Auxito
Spark plug socket stuck
Old Mar 17, 2017 | 12:04 PM
bass-n-fire's Avatar
bass-n-fire
i just purchased an '01 expedition with the 5.4. I was told #5 spark plug blew out. Upon examination, it appears to be #6, second from the front driver side. Anyway, as I was looking, it just didn't look right. There was a spark plug socket stuck in the well, with the plug still in place. Any suggestions on how to get the socket out? I can get an extension on it and it will turn, but it's tight. But I can't pull the socket out.
Old Mar 17, 2017 | 12:12 PM
projectSHO89's Avatar
projectSHO89
Can you get a tool with a bent tip to get in through the 3/8" opening, hook the inside of the socket, and use that to pull it out?
Old Mar 17, 2017 | 12:55 PM
steve(ill)'s Avatar
steve(ill)
long needle nose pliers.
Old Mar 17, 2017 | 02:12 PM
jwh's Avatar
jwh
Also for changing plugs in my truck I bought a gear wrench socket that has a permanently attached extension. Kept loosing the socket in the hole once the plug was tight.
John
Old Mar 17, 2017 | 03:24 PM
projectSHO89
It sounds like that, beside the socket being stuck in there, the thing will turn but the plug won't back out suggesting a failed insert or helicoil or a set of stripped threads.
This is going to be messy....
Old Mar 17, 2017 | 06:11 PM
bass-n-fire
I've been trying to get it out with a pick. Not having much luck. Thinking about starting the truck to see if it will blow out again.
Old Mar 17, 2017 | 08:00 PM
alloro's Avatar
alloro
Get an extension in it, then turn it rapidly with an air tool or drill as you pull it upward. The trick here to try and break the friction as you're lifting.
Old Mar 29, 2017 | 10:26 PM
Austin J.'s Avatar
Austin J.
Put some gel super glue on the end of the extension. Then insert it into the socket and wait 10 minutes. Shouldn't have any issue pulling it out. Dip it in acetone to dissolve the superglue. I super glue the extension and spark plug socket together every time I install spark plugs in a triton.
Old Apr 2, 2017 | 02:14 AM
newfordy's Avatar
newfordy
get a locking extension like Craftsman sells, spray some solvent like WD40 then use the extension as a handle to pull on.
just an idea
Old Apr 5, 2017 | 10:22 PM
bass-n-fire
Finally got it out. Mystery oil and a pick. Thanks for all the input.
ugltrk
Aerostar
13
Jan 10, 2018 05:03 PM
dannymo
1997 - 2003 F150
21
Feb 18, 2008 09:27 PM
BigDASH
Sep 6, 2006 11:54 AM
Mr.Ford 351W
Garage & Workshop
18
Sep 15, 2005 04:01 PM
Keymaster
1997 - 2003 F150
Mar 6, 2005 12:27 AM
