i just purchased an '01 expedition with the 5.4. I was told #5 spark plug blew out. Upon examination, it appears to be #6, second from the front driver side. Anyway, as I was looking, it just didn't look right. There was a spark plug socket stuck in the well, with the plug still in place. Any suggestions on how to get the socket out? I can get an extension on it and it will turn, but it's tight. But I can't pull the socket out.
Also for changing plugs in my truck I bought a gear wrench socket that has a permanently attached extension. Kept loosing the socket in the hole once the plug was tight.
It sounds like that, beside the socket being stuck in there, the thing will turn but the plug won't back out suggesting a failed insert or helicoil or a set of stripped threads.
Get an extension in it, then turn it rapidly with an air tool or drill as you pull it upward. The trick here to try and break the friction as you're lifting.
Put some gel super glue on the end of the extension. Then insert it into the socket and wait 10 minutes. Shouldn't have any issue pulling it out. Dip it in acetone to dissolve the superglue. I super glue the extension and spark plug socket together every time I install spark plugs in a triton.
