´56 ...not a "build thread" more a "modification thread"...
Old Nov 26, 2023 | 08:26 AM
  #316
ingo's Avatar
ingo
It seems your Calipers are in the same angle than mine.
The droped spindles doesn´t matter.
You have no visible steering stop? So the steering stop must be inside the rack, right !?
Is there a chance you measure the steering travel?
Ingo
Old Nov 26, 2023 | 09:53 AM
  #317
Another rusty Ford's Avatar
Another rusty Ford
I believe the steering stop is in the rack, from lock to lock it is 2 1/2 full turns
Old Nov 26, 2023 | 02:53 PM
  #318
ingo's Avatar
ingo
Originally Posted by F100fun
Odd, the kit I got from TCI has the sway bar underneath. I didn't do the coil over set up, just shocks and coil springs so maybe that is why my sway bar is under everything. No interference issues on mine.
Jim
Hey Jim,
do you have a Photo from the rear of your IFS, where the swaybar brackets are attached to the crossmember?
Old Nov 27, 2023 | 04:50 AM
  #319
F100fun's Avatar
F100fun
Originally Posted by ingo
Hey Jim,
Sorry for the delay, I was not home most of yesterday. Here is probably the best pic I could find.
Jim
Old Nov 27, 2023 | 04:57 AM
  #320
F100fun's Avatar
F100fun
One other thought. Does it hit on both sides or just one? If just one, did you center the steering rack before installing it.
If I recall correctly the process is to pick a point on the rack with the rack turned all the way to one stop, take a measurement front one threaded end to the point you picked on the rack, then turn rack to the opposite stop, take measurement from the same threaded end you started with to your original point on the rack, subtract the two measurements and divide by two and set the rack to that measurement which should be center.
Jim
Old Nov 27, 2023 | 07:04 AM
  #321
Another rusty Ford
A difference I noticed between yours and mine is I have a bracket on the lower control arm for the swaybar for mounting where yours actually has the swaybar mounted to the bolt that holds the shock absorber in place on the lower control arm from what I can see in your pictures
Old Nov 27, 2023 | 07:38 AM
  #322
ingo's Avatar
ingo
Jim
Thank you very much.
That's interesting...your crossmember has extra outriggers downwards to be able to mount the brackets further down. In contrast, I had to mount my Swaybar mount above the A-arms.
Old Nov 27, 2023 | 07:39 AM
  #323
ingo's Avatar
ingo
Jim
Yes thats what the instruction says and what i did, so it´s centered and i hits on both sides.
Old Nov 27, 2023 | 07:41 AM
  #324
ingo's Avatar
ingo
Yes thats a difference. But i don´t think thats the Problem because the steering arm hits the swaybar and additionally the Caliper hits the coilover.
I now go check how many turns i have from lock to lock... i´m pretty sure it was more than 3.
Old Nov 27, 2023 | 07:34 PM
  #325
ingo's Avatar
ingo
I have 2 1/2 turns also.
Have any of you ever installed these steering travel limiters?
Mustang-Steering-Limiter-Spacers Mustang-Steering-Limiter-Spacers
Old Dec 14, 2023 | 04:39 PM
  #326
ingo's Avatar
ingo
After watching a Youtube Video how the Steering Rack Limiter Stop Spacers to install and how they work it was easy to fabricate them by myself on the Lathe...
first try:
...didn´t work perfect, so
2nd try:
turned the spacers from plastic, that worked perfect for me.
Old Dec 17, 2023 | 08:01 AM
  #327
330pbr's Avatar
330pbr
i recently got the TCI ifs for my 56 and was wondering if you guys had to cut alot of your frame rails back to fit the xmember in between?
seems like i have to remove about 3/8 from each side
Old Dec 17, 2023 | 08:37 AM
  #328
56panelford's Avatar
56panelford
Outside to outside of your frame should measure 34 inches and square up and down. Does your frame still have the transmission cross member in it? Your frame rails could be twisted some..
Old Dec 17, 2023 | 11:50 AM
  #329
330pbr's Avatar
330pbr
it is 34.... alittle bent in and has all crossmembers
Old Dec 22, 2023 | 06:45 AM
  #330
ingo's Avatar
ingo
If I remember correctly, the lower leg of the frame profile is longer than the upper one, this must be shortened, nothing else.
