RAM vs. CHEVY vs. FORD
Old Mar 4, 2017 | 10:16 AM
  #76
Scott Zuspan's Avatar
Scott Zuspan
The 2017 does let you know on the dash that it is going into regen mode. It states that Regen mode is now active, continue to drive... It also, finally, lets you know how much DEF you have in your tank now as well.
Old Mar 4, 2017 | 11:04 AM
  #77
K2500Z71's Avatar
K2500Z71
Originally Posted by EpicCowlick
The truck I sat in had an MSRP of $67K and I didn't catch which package it was. One guy said it was a "loaded" truck.
It was probably pretty close to loaded given that a GMC Denali SRW can barely touch 70K MSRP. GM doesn't really have anything that compares to the KR and Platinum trim levels. A Lariat Ultimate is probably a fair cross shop comparison to a Denali based upon what I've seen.
Old Mar 4, 2017 | 05:14 PM
  #78
wec512's Avatar
wec512
Originally Posted by troverman
I'm disappointed in the results of this Ford. A couple of things - when the instruments were shown on the downhill run, I can see Tow/Haul is lit, but I cannot see the indicator for the exhaust brake being turned to full on or auto. Its possible its being obscured by the tach bezel, but I can see most of the odometer.
Now oddly, on the uphill run, the one shot where they show the cluster, look at the boost gauge. It is only running about 20psi. At wide open throttle up a hill like this, it should be running closer to 30psi. Heck, I've seen close to 30psi on much smaller uphills.
You could blame the Ford's slower performance on the other trucks simply being "ringers" or the Ford being "a dud," but these were the same trucks in the 0-60 run, where the Ford was quicker than both these same other trucks!
Fuel economy is kind of silly. They are determining the result simply based upon the dash computer. Who knows how accurate they truly are.
Is it possible some weird transmission shifting prevented the Ford from being where it needed to be? Not sure. It seems the "Midnight IKE" from a few months ago with the 450 towing 30k up the IKE was quicker than this truck!
You comment has me thinking.... when I read the manual, it says .....
"The tow/haul feature:
• Provides engine braking in all forward
gears, which slows your vehicle and
assists you in controlling your vehicle
when descending a grade"
This leads me to believe you get engine braking when you select the Tow/Haul mode by itself. It says nothing about turning on the engine brake with the engine brake switch. Maybe it is an assumption you will turn on the engine brake in addition to the Tow/Haul mode. I will have to test this out when I get in the right conditions with a load.
Old Mar 4, 2017 | 05:21 PM
  #79
lkbrow1's Avatar
lkbrow1
Tow/Haul mode locks the torque converter. I made good use of it towing a 9000 lb trailer up and down a 21% grade in Canada this summer.
Engine brake adds to this by blocking the Exhaust further allowing the engine to retard your speed.
Old Mar 5, 2017 | 10:29 AM
  #80
ROADRUNNER1's Avatar
ROADRUNNER1
Mine doesn't show when it's in regen mode. I still think it was in regen during this test because of the lower turbo boost reading. That's what region does, lowers turbo boost and increases fuel to burn off soot buildup. Both of those happened from the very little video we got to see. I want to see the whole 8 minutes of the run. 15 seconds is not very long and there could have been a slower truck in front of them at some point that they had to wait and pass. Very weird they didn't show the whole run like they usually do.
Old Mar 5, 2017 | 10:44 AM
  #81
LOWRPMTORQUE's Avatar
LOWRPMTORQUE
As a opened minded truck shopper I have the following thoughts on this video.
In my opinion TFL Truck is like the rest of the media these days, they lake credibility. I usually mute the audio. The avg. user here could do a better job of asking the right questions and coming up with better "tests" than these guys.
They use 6 mpg as a benchmark for all vehicles running up the Ike. It does doesn't matter if the vehicle is towing 5k or 30k. On top of that they rely on the mpg listed on the MFD. These numbers mean nothing to me.
Each truck pulled the same trailer up the same 8 mile hill at DIFFERENT times. With the following results.
The Duramax at 10m 17s for an avg speed of roughly 46.7 mph
The Cummins at 45.8 mph
The Powerstroke at 45.6 mph.
So the Duramax was about 1 mph faster, big deal. One of the "testers" says the Ford "just wouldn't trudge up the hill". What the hell is he talking about?
Old Mar 5, 2017 | 11:33 AM
  #82
Adam R's Avatar
Adam R
Anyone who has done legitimate testing knows you don't rely on a single data point. TFL should have known from their own testing of the F450 a few months back that something wasn't quite right. I think, in the back of their minds, they did question the results, but forged ahead with the numbers they captured on that single run. Will it sway me away from buying a Ford, no, but I'd like to see what truck really can do at a 23K weight. I think it would be fairer to all 3 brands to have 2 or 3 runs in a day per vehicle to ensure you have consistent and repeatable results. Up and down the pass in 30 minutes, 15 minutes to change the trailer to a different truck and repeat 9 times. Long day, but we'd have more confidence that the results were accurate. As a I mentioned earlier, if the F-450, at 32% heavier is only 8% slower going up the hill, something is off.
Adam
Old Mar 5, 2017 | 07:26 PM
  #83
99SuperDuty2017's Avatar
99SuperDuty2017
Can Ford increase HP and Torque numbers by updating the tune on the 2017 6.7??? Or is this just wishful thinking???
Old Mar 5, 2017 | 08:11 PM
  #84
FishOnOne's Avatar
FishOnOne
It was reported that the FLT made two runs with the Super Duty so it wasn't a regen issue.
Old Mar 6, 2017 | 07:56 AM
  #85
troverman's Avatar
troverman
Originally Posted by Adam R
Generally, Mr. Truck does some fairly decent testing and videos, but something was amiss with this truck especially when you extrapolate the data they recently provided with a 2017 F-450. The F-450 was 30.43% heavier, but only 8.4% slower up the hill. While not everything is linear in a comparison like this, something is definitely off. Would have been nice if they had taken the time to do a second test, because at some point, you are going to catch a truck in the middle of a regen running up the pass. A second run would have confirmed the truck was indeed slow or was down on performance due to something like a regen. Alas, these guys are not test engineers, but a little more rigor in the tests would be nice.
I hate to say it, but the F-450 and trailer and load was all supplied by Ford at a major press event. Although I doubt it, Ford could have supplied an "over-performing" truck and / or an underweight trailer for the event, since there was no opportunity to weigh the truck.
Old Mar 6, 2017 | 07:57 AM
  #86
troverman's Avatar
troverman
Originally Posted by diesel toes
One thing not talked about is fuel quality. Where did they fuel up? Did they use the same fuel station and same pump?
They always fuel the trucks up at the same station / generally the same pump. Appears to be a high-volume station / truck stop.
Old Mar 6, 2017 | 08:00 AM
  #87
troverman's Avatar
troverman
Originally Posted by 2009kr
At 19:43, you can see that ~3000 RPMs is just over 50 MPH. That is what I would expect in 3rd gear with a 3.55 rear. I think they would have had a much better climb time with the 4.10.
Is it possible they got confused and were given a truck with the 3.55 axle? These trucks are supplied by the manufacturer...with all the sticker mix ups, is it possible the wrong window sticker was supplied? Or TFL screwed up?
Old Mar 6, 2017 | 08:16 AM
  #88
theboom's Avatar
theboom
Well then why do you think the Ford lost when it has 5hp less 15ft lbs more and 4.10 gears? It should beat it. And assuming the test with the 450 was legit, when towing 30k, it beat the ram by over a minute.
Old Mar 6, 2017 | 08:22 AM
  #89
Mxsledder's Avatar
Mxsledder
Originally Posted by 191124x7
Something to think about (and I'm no engineer), but 99.9% of everything in life is a compromise. If you build for power you give up some speed. Build for speed and give up some power. Because the Ford is the winner in capacity perhaps that creates a trade off in speed / mileage.
It would have been awesome if the Ford had been the clear winner, but I don't regret buying my Ford one bit after seeing this video. In my (getting to be many years of) experience:
- The Rams are solid on the outside and junk on the inside
- All GM products are junk (I've never owned a Chevy truck but many Cadillacs, Buicks, and Oldsmobiles) -- stranded many times, huge repair bills, much time in the shop. I wouldn't buy the truck in the video for 50% of what they were asking for it unless to flip it (and even then I'd feel guilty selling it to the next buyer)
- The many Fords I have owned are solid on both inside and out. I can think of only one issue that left me stranded with all of my many Fords (trucks, cars, and SUV's).
They can test my truck on video, and roll it up and down that hill - but I still wouldn't (ever) trade it for a coup de ville (with a pick up box).
The new rams are extremely nice inside! The old theory that rams are junk inside ended in 2010. Don't get me wrong I love my 2017 f-350 but to say the new rams are junk inside is just completely false.
Old Mar 6, 2017 | 09:14 AM
  #90
troverman's Avatar
troverman
I agree. Too many people generalize. Just because some vehicle wasn't that great during a few years, doesn't mean they are junk forever.
If I wasn't driving a Ford, I'd likely be driving a RAM, despite hating the fact that ownership of the company is foreign. Parts of the GM trucks appeal to me, but not enough parts!
