RAM vs. CHEVY vs. FORD
Old Mar 7, 2017 | 01:39 PM
  #136
camping nut's Avatar
camping nut
I just measured my 2016 Platinum with 20" wheels. I also have my hitch in the back and it is very close to 82" at the back of the cab.
Old Mar 7, 2017 | 01:41 PM
  #137
JT_Guitar's Avatar
JT_Guitar
Oh sh#$... My garage is 82"...
Update... Fit under the garage door by 1/2".
Old Mar 7, 2017 | 01:49 PM
  #138
JasonB1's Avatar
JasonB1
FWIW, I sold my 2011 to my friend and I park next to him in my 2017.
The two trucks (both F-250 diesels, 2011 KR, 2017 Plat) are virtually identical in the front, but the 2017 is at least 2" taller, tailgate to tailgate.
Not sure on the roof heights, but 1'5 to 2" would probably be accurate.
Old Mar 7, 2017 | 02:00 PM
  #139
troverman's Avatar
troverman
Originally Posted by Strokin-A-2010
I'm thinking my truck is close to 83" if not 83" dead on. I pulled my truck as far in as I could and right over the rear seats is when I stopped cause another inch forward it would had scraped. I probably still had another 8-10 inches to go till the whole cab would had been in the garage.
The more I think about it, the more you might be correct. Those dimension guides do not specify which wheel is used...if it is a base 17" wheel on an XL model, the overall height would be less. This might explain the discrepancy we see between your measurement and the 81.3" factory measurement. However, it would not explain the discrepancy between a direct measurement of a 2016 to a 2017, assuming comparable tire sizes.
Old Mar 7, 2017 | 02:18 PM
  #140
JasonB1's Avatar
JasonB1
Depends on where you take the measurement, too.
Just eyeballing it, you can see the rear roof line is higher than the leading edge on the cab.
Again, this assumes identical trucks, trim levels, etc.
Old Mar 7, 2017 | 05:42 PM
  #141
Strokin-A-2010's Avatar
Strokin-A-2010
Here's my truck next to my co workers, exact same tires size both f350 with 20" wheels Fx4. The only difference is his is a lariat and mine is a KR. Both beds are empty and his tool box is completely empty.
Old Mar 7, 2017 | 06:14 PM
  #142
ruphianh's Avatar
ruphianh
selling my ford now
Old Mar 7, 2017 | 06:34 PM
  #143
Strokin-A-2010
Originally Posted by ruphianh
selling my ford now
um........ok hope you're joking.
Old Mar 7, 2017 | 06:51 PM
  #144
JasonB1's Avatar
JasonB1
Pretty much what ours look like. Front is pretty close to even, but the rear is way different.
That's why I had to bed steps to the 17. Even at 6', I couldn't reach in the bed behind the cab.
Old Mar 7, 2017 | 07:08 PM
  #145
The Ace of Spades's Avatar
The Ace of Spades
​​​​​​​how heavy do you think that ranch hand bumper is?
​​​​​​​also, are you sure that black truck is an F350? It seems to be sitting lower, like an F250.
Old Mar 7, 2017 | 07:09 PM
  #146
Strokin-A-2010
Actually my front end is at least 2" taller. And yea I'm 6'4 and can't reach all that far into the bed on my truck.
Old Mar 7, 2017 | 07:11 PM
  #147
Strokin-A-2010
They aren't ranch hand. I actually install those for him and I believe the front weighed 150-175 pounds and the rear was around 75.
Old Mar 8, 2017 | 12:06 AM
  #148
kry226's Avatar
kry226
I think it's time we stop bashing these manufacturers about quality and dependability don't you think? I think they're doing a hell of a job considering the tolerances and rules that they have to abide by.
is the 6.7 or Ford trucks in general, thought of as unreliable? If so, I never knew it.
No, I don't, but I have no interest in bashing anyone. And I wasn't talking specifically about the Ford. I think it's time we lost the Fan Boy mentality with ALL manufacturers and start taking them to task. These trucks cost a mortgage, and to have you're engine replaced at 300 miles, or your driveway covered in tranny fluid is ridiculous. Do you call that dependable or quality? And none of that has anything to do with EPA or regulations. The Ram and GM trucks have their quality issues too, goes the same for them. The L5P isn't exactly without it's own teething issues.
I'd certainly buy the last truck to the top of the mountain when I know it'll actually make it to the top of the mountain, and then get me back home too. When the MFRs finally know we'll vote with our feet and not buy a truck just because that's the truck Daddy had, I think we'll find we have their strict attention.
And I, for one, will never stop expecting a better product for my money.
Old Mar 8, 2017 | 05:10 AM
  #149
Strokin-A-2010
The trucks with that oil pressure issue about replacing the engine and the transmission lines leaking is less than 1% of the 2017 super duty trucks that have been made. Less than 1%. You act like there are trucks having their engine replace left and right. So yes I call that dependable and realible.
Old Mar 8, 2017 | 06:54 AM
  #150
Fmc4lfe's Avatar
Fmc4lfe
I definitely think something was off in this test however we all have to admit that chevy has always done a good job at getting their power to the pavement!!
