Headlight Bulb Upgrades
Old Jan 22, 2017 | 10:20 AM
  #31
09f250v10's Avatar
09f250v10
Xenon Depot
Originally Posted by Mystic_Cobra
Please do report back. I am looking for a few more "data points" before I make a purchase.
Will do sir, I was trying to decide between The HID Factory H13 kit and the Xenon Depot H13 kit. I personally went with the Xenon Depot kit for multiple reasons. They use Phillips LEDs, flat led chips rather than domed, clockable base, anodized copper heat sink rather than a fan, and I've read great things about thier customer service. It just seems like they really focused on chip type, board type, bulb length, led position, etc. to get the best optics possible in halogen housings. The only reason I hadnt pulled the trigger on led bulbs yet was because I personally had not found any that you could adjust the base on to get the right pattern. Since the Xtreme's do, I felt better dropping the coin. I will definitely do an honest report on their performance once I get them in.
Old Jan 22, 2017 | 10:44 AM
  #32
my_crib_too's Avatar
my_crib_too
Please post a few pictures and comment on the installation process too. Before and after beam shots.
Bruce
Old Jan 22, 2017 | 12:19 PM
  #33
Superduty450's Avatar
Superduty450
Well I think you guys have convinced me to go LED over just the Philips bulb upgrade, its only a few dollars more and they will probably last longer
Old Jan 23, 2017 | 01:17 AM
  #34
KodiakF250's Avatar
KodiakF250
I'm also curious about the can bus choice. I don't want any lamp-out warnings or error codes, and I'm concerned that buying LEDs without can bus might do that. When I bought my 2014 used, the dealership I bought it from had removed aftermarket HID headlights from the truck because they were throwing a code. That is what's making me wonder.
Old Jan 23, 2017 | 02:23 AM
  #35
EO2SeaBee's Avatar
EO2SeaBee
I have no codes or warnings due to LED's in my heads, fogs or reverse light sockets.
Old Jan 23, 2017 | 07:35 AM
  #36
cangim's Avatar
cangim
This is my experience as well...
Old Jan 23, 2017 | 08:15 AM
  #37
djousma's Avatar
djousma
There is an option that can be changed with Forscan that turns off the lamp-out warning when using LED's. If you don't want to go that route, your local Ford dealership can do it too, but for a cost. I see no reason to buy the CAN-bus module
Old Jan 23, 2017 | 10:27 AM
  #38
09f250v10's Avatar
09f250v10
Oh well
Over the weekend I had emailed Xenon Depot about whether or not I needed the canbus modules. I ended up ordering the kit without the canbus modules based on cangim saying he had the kit without the modules for 2 years. Of course, Xenon Depot gets back to me today saying that I DO need them for the 2016 250. I may just have the BCM reprogrammed like people have said in this thread and call it good.
update: Xenon Depot replied to me a second time saying that the H13 Led kit is backordered but expected to be in this Friday AND that they included the CANBUS modules free of charge for when the order ships. Great customer service!
Old Jan 23, 2017 | 05:21 PM
  #39
Dakster's Avatar
Dakster
Let me know how it goes 09f250v10....
I'm doing my research as well. Right now more focused on getting a traction aid for tires though since this is turning out to be a real winter.
Old Jan 26, 2017 | 09:43 AM
  #40
BIGTRUCKBIGRV's Avatar
BIGTRUCKBIGRV
I just tried swapping my headlight bulbs out with LEDs and did not have great results.
Old Jan 26, 2017 | 09:48 AM
  #41
Superduty450
Please elaborate on what the issue was with the LED swap
Old Jan 26, 2017 | 10:06 AM
  #42
swarf_rat's Avatar
swarf_rat
Also, the brand matters.
Old Jan 26, 2017 | 10:09 AM
  #43
BIGTRUCKBIGRV
You can see for yourself sir. The beam pattern looked like crap.
https://www.youtube.com/watch?v=qaiaq9b68z0
Old Jan 26, 2017 | 03:31 PM
  #44
swarf_rat's Avatar
swarf_rat
There are probably a hundred different LED retrofits, maybe more. Did you try all of them or just one particular brand?
Old Jan 26, 2017 | 09:16 PM
  #45
my_crib_too
Thank you for the video. I enjoyed it.
Bruce
