Nickel/Copper Brake Line
I recently ran all new lines (hard and soft) on my truck wile doing a manual to power brake conversion and used these lines. Very easy to work with and very forgiving. I ordered 50' of this stuff and even having to run from the factory valve on the frame to the new one on the master cylinder, it is enough. If you are in the need of a great flaring tool, check out the Mastercool Flare (71475) makes flaring easy and turns out perfect flares every time. It will also do transmission and fuel lines. So easy to do, my daughter flared almost all of the lines.
I also made a tool to straighten the line. Just a scrap piece of metal and some v-groove bearings off of eBay. Run it through a few time and it is straight and ready to go:
Jackford
07-14-2022 06:09 AM
neilc88
19
07-15-2012 10:00 PM
64F260
13
03-05-2007 10:24 AM
