I've yet to see a USA brake line that's not double flared! Every Google search I've done says the bubble flares are acceptable for everything BUT hydraulic lines.
It seems the bubble flare is acceptable with the special backing nuts but even so with the long time common use of double flared brake line and its more than acceptable performance I'd not be looking to reinvent something so successful for at least 70 years.
Note to self...when working underhood, do not refer to this area as the front of the vehicle. Begin to refer to it as the rear. Enjoy the look of consternation on peoples' faces right before they call me an a-hole.
Anyway, to neilc88...enjoy that copper-nickel line! We sell a bunch of it where I work, and just last week I made new trans cooler lines for my dad's Excursion...it worked like a charm. Easy to bend, and easy to flare. I never double-flared anything before in my life, and this stuff made me look like I was born with a flaring tool in my hand.
Just make sure you have a GOOD, quality flaring tool. I ended up using a KD #2199 that I borrowed from a techie buddy, after it was obvious the Chinese tool I got at Advance (I know...I know) was a total POS.
Good luck...
Pat
+1 on a good quality tool for this job---IMHO its too important for most any application to use anything less.
Pat you've never double flared even brake lines? I've always been told and used the double flare myself---can't recall anyone not doing it. Would be interested to know if it works just as well.
