Old looking brake lines -
Old Sep 13, 2005 | 07:39 PM
Jackford's Avatar
Jackford
Had the machinic upgrade my engine to a 390 for a number of reasons related to age of the moter. The other day I noticed a brake line had been broken and joined back together using a rubber hose and a couple of clamps.
Not sure how efficient this brake line repair is? I am thinking of replacing all brake line back to the master cylinder.
How difficult a job is this and what kind of expense should I expect in doing it myself. Also will I have trouble in finding the brake lines etc?
Jackford
Old Sep 13, 2005 | 09:13 PM
jor's Avatar
jor
That kind of fix for a brake line sounds like a real BAD idea. I think your best bet would be to find a replacement at a wrecking yard. Failing that you can make your own but it's a bit tricky.
jor
Old Sep 13, 2005 | 09:59 PM
78fordman's Avatar
78fordman
i would say buy the line and a bender and go for it. just replace it line by line, that way it is new also. Might have a hard time getting a line from a junkyard, trying to get the thing off without breaking. your call though.
Old Sep 13, 2005 | 11:19 PM
mblayton's Avatar
mblayton
That garage should be out of business if they fix brake lines like that, are you sure it's a brake line and not a tranny cooler line? Most auto parts stores carry lines already made to different lengths flared and with the fittings, usually 5-6 bucks each all you need to do is bend them and install
Old Sep 13, 2005 | 11:22 PM
GLR's Avatar
GLR
Go for all new lines, get a coil of brake line, some fittings and a double flare tool. Follow instructions for flaring (don't forget the fittings). Waste of time trying to use old brake lines.
Old Sep 14, 2005 | 11:12 PM
Chevy_Eater's Avatar
Chevy_Eater
Now that's a hairy fix!!!
Old Sep 15, 2005 | 06:42 PM
go_racing84's Avatar
go_racing84
I second that... I think a repair like that would fail the first time you pushed the pedal
Old Sep 17, 2005 | 06:47 PM
Jackford's Avatar
Jackford
Red face My mistake ----
I stand corrected.
I rolled up my sleeves today and got under the truck to take a closer look at what I first thought were brake lines. It was the line from the radiator to the transmission that had been patched.
I wonder if this is an accetable method of repairing this line?
Old Sep 17, 2005 | 06:54 PM
zsir's Avatar
zsir
Originally Posted by Jackford
I stand corrected.
ooops.....thats a lot different.....it's not a big deal at all....especially if the lines were semi flared.....that's the first part of a double flare.....if it's not leaking don't worry about it....
Old Jul 13, 2022 | 02:23 PM
Mechanixchix77's Avatar
Mechanixchix77
6th Gear
Rescued 2000 Expedition XLT4x4
Couldnt be a more true piece of advice that I’ve ever heard!!
Old Jul 13, 2022 | 06:29 PM
Chevy_Eater
Holy 17 year old thread Batman!
Old Jul 13, 2022 | 08:09 PM
Mechanixchix77
6th Gear
sorry lol learning to navigate and I happen to be dealing with same issues on the expy I’m rehabbing, just rang true to me.
Old Jul 14, 2022 | 12:16 AM
1TonBasecamp's Avatar
1TonBasecamp
Personally I like some of the discussions that get dredged up from the past. I missed them the first time around so it is fun to see what was going on back then.
Old Jul 14, 2022 | 02:10 AM
Obscure69's Avatar
Obscure69
Pretty impressive that a 17 year old thread re-appears :-)
All new brake lines is the only way to go in my opinion. Even if you were able to find one at a junk yard, and was able to remove it without breaking it, it will be 40-50 years old (I suppose it could have been replaced...) Considering that brake lines are relatively cheap, and pretty simple to replace, and a quite important part of a safety feature, I can't see ever reusing an old line.
Old Jul 14, 2022 | 06:09 AM
GLR's Avatar
GLR
There is always some good info or advice on this site, No matter how old the thread.
