Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread part 3-2017
Old Jul 28, 2018 | 01:42 PM
  #7651
fire240's Avatar
fire240
replacing tent poles does not happen too often. Usually only when one cracks, or rots or is otherwise damaged. Each tent is different so each set of poles is pretty much custom made for each tent. The poles I have to make are actually for a brand new tent.
Old Jul 28, 2018 | 01:44 PM
  #7652
Steve GG's Avatar
Steve GG
What is the color paint you use Shaun.. a white or a vivid color??
not sure about the at Morris.. I son-in-law says he has a 50 foot hose for me. Will see how that works..
Old Jul 28, 2018 | 01:46 PM
  #7653
Fomoko1's Avatar
Fomoko1
As long as there aren`t too many poles and you don`t have to do it very often then it`s manageable.
I got a 50 foot hose for my pressure washer which sucks in a way, it`s a lot bulkier and heavier than the 25 foot one that came with my pressure washer.
Old Jul 28, 2018 | 01:56 PM
  #7654
Steve GG's Avatar
Steve GG
This one is free so may offset any downfalls.. then again it might not..
Old Jul 28, 2018 | 01:57 PM
  #7655
fire240's Avatar
fire240
It is a custom colour Steve. It is a grey with a very slight touch of blue in it. Morris for teh standard privates tents it is 1 ridge pole and 2 uprights for the ridge pole. For a marquee tent it is 1 ridge pole and 2 uprights. Teh wall tents are where you have alot of poles. The wall tent I have has about 10 perimeter poles which are 2"x2" and 4'2" tall. 1 ridge pole at 2"x4" that is cut to a certain shape and that is 11'5" long, and 2 uprights for that ridge pole that are 2"x2" and 8' tall.
Old Jul 28, 2018 | 02:01 PM
  #7656
Steve GG's Avatar
Steve GG
Yep, Shaun, you are going to be busy..
Old Jul 28, 2018 | 02:13 PM
  #7657
fire240's Avatar
fire240
Well luckily I only have to make poles for one wall tent which is brand new as well as the tensioners, and ropes. And paint the tensioners and poles.
Old Jul 28, 2018 | 02:15 PM
  #7658
fire240's Avatar
fire240
All of the other poles are in good shape except for a bit of touch up painting.
Old Jul 28, 2018 | 02:45 PM
  #7659
Steve GG's Avatar
Steve GG
So you have 2 tents that you are getting ready for the next event.l
Old Jul 28, 2018 | 03:34 PM
  #7660
56panelford's Avatar
56panelford
Good afternoon everyone, having a little thunder shower passing over right now. Had some guys I used to work with stop over to visit so took advantage and had them help me remove the hood on the panel..now I have something to do tomorrow, inner and outer fenders..
Old Jul 29, 2018 | 12:18 AM
  #7661
Fomoko1's Avatar
Fomoko1
The original 25 ft pressure washer hose developed a leak in it or else I`d be tempted to go back to it Steve.
Too bad the tent poles couldn`t be made of steel, that should last a lot longer then wood Shaun.
I never turn down free help either John, especially when it happens at the right time.
Old Jul 29, 2018 | 07:09 AM
  #7662
fire240's Avatar
fire240
Morning MB and SK.
Old Jul 29, 2018 | 07:13 AM
  #7663
fire240's Avatar
fire240
No Steve. Just one needs new poles. A few poles we need to do a bit of spot painting on. Just a tiny bit of paint on a few other poles. Although the tents that the poles that need touch up painting done need to be replaced with new tents. But that is an expensive.
I know it would be but those poles would be really heavy for reenacting use.it is bad enough we use canvas tents which already weigh alot.
Old Jul 29, 2018 | 10:22 AM
  #7664
Steve GG's Avatar
Steve GG
Good morning M/S, Morris, John, Perry, Grant, Shaun and anyone else ambling through here..
Old Jul 29, 2018 | 10:23 AM
  #7665
fire240's Avatar
fire240
Howdy Steve.
