Whack customers are easier to get rid of then whack bosses....just saying.
It`s going to be hot here Tomorrow and Monday then mid 20`s which I can handle better.
That`s a lot of rain and snow, tornadoes would scare the crap out of me!
We see them but it is not very often. Usually occurs south of the city But Baltimore has seen one or two here and there. Sometimes the hurricanes or tropical storms will spin up tornadoes. Nothing like a storm that can be hundreds of miles across with winds pushing 75+ miles per hour with rain a calm center and then the other side comes through with winds in a different direction and just as strong if it is a hurricane. Tropical storms have winds between 45 and 74 mph. And I get to go to work in weather like that because I am essential personnel.
the pressure washer pump arrived and I have installed it.. It seems to be working but maybe not as powerful. Motor sounds strong.. made some wasps mad by accident.. thought I was going to get stung..
Usually use untreated pine. Doesnt need to be fancy since it will be painted. But I need 1 2x4x12, 2 2x2x8's, and quite a few 2x2x6's. After I get teh poles cut and fit to the tent as well as painted I can start working on getting the 70 feet of manila rope cut into the proper lengths.
Sounds like you have a bit of work a hard of you Shaun.. I used ripped 2x4 penetrated for my tarp poles with a galvanized screen in the top that fit in the grommets.
A bit of work for sure Steve. Hardest part is cutting and whipping the rope as well as putting on the tensioners which will also have to be cut, drilled, and painted.
