07 Ran Ragged
Old Jan 1, 2017 | 07:14 PM
seijirou's Avatar
seijirou
lol wow sounds like fun
Old Jan 2, 2017 | 11:53 AM
Sarge261's Avatar
Sarge261
Heres some pics of the standpipe, looks like I have all the pieces...thank god.
Old Jan 2, 2017 | 12:07 PM
87crewdually's Avatar
87crewdually
Yup, seen that before.
Mine broke when I reinstalled a new filter after an oil change so I didn't even know the tabs broke. About 15 miles later it died on a turn & I was towed home. Wiped out my HPOP.
Old Jan 3, 2017 | 01:20 PM
Sarge261's Avatar
Sarge261
Guess I got lucky and found all the parts then.
Sarge
Old Jan 3, 2017 | 05:52 PM
Yahiko's Avatar
Yahiko
So you think at oil change that we should start taking a close look at
the top of the stand pipe to see if it's in good shape?
I wonder if it should just be replaced after spending it's service life
in oil. How many years do you think it takes for the plastic to
start to get brittle in that environment?
Also is the stand pipe Ford only part or can I get one from IH?
Anyone have the part number for the IH one if there is one?
Old Jan 3, 2017 | 07:41 PM
87crewdually
You can probably guess what I think. These trucks are getting old. With all the heat cycles the plastic gets brittle. For a round number rule of thumb if it's 10+ years or 100+ thousand miles I'd change it. If your doing an oil cooler, change it. That's my thought.
Oil return tube $35-40 bucks
Ford 3C3Z-6C755-AA
International# 1840755C92
Old Jan 3, 2017 | 10:46 PM
Yahiko's Avatar
Yahiko
Thank You for the part numbers. I think that is going to be
on my parts to order list.
Old Jan 4, 2017 | 07:35 AM
Sarge261's Avatar
Sarge261
I agree,
Now that the newest of the F-series is 10 years old I'm going to add this to the list when I do oil coolers now. Ill take a peek at my truck at the next oil change in the spring. For reference this particular truck has 218,000 miles on it and the last tech...well, lets just say hack!
Sarge
Old Jan 4, 2017 | 04:24 PM
Yahiko's Avatar
Yahiko
I have to do an oil change in the next few days. I am thinking
that if I can get my hands on the part before I do the change
that I will also change that too.
Old Jan 4, 2017 | 04:33 PM
87crewdually
And while you are in there inspect the oil bypass valve.
Old Jan 4, 2017 | 05:00 PM
Yahiko's Avatar
Yahiko
Has anyone come up with a viable replacement for that part?
Old Jan 4, 2017 | 05:53 PM
87crewdually
https://www.ford-trucks.com/forums/1...erences-2.html
Pick it up around post #18.
Old Jan 4, 2017 | 08:11 PM
  #28
Yahiko's Avatar
Yahiko
I will have to go read that. I took a quick look. Have you used the part?
Thanks for the link.
Old Jan 4, 2017 | 08:27 PM
  #29
Tideman's Avatar
Tideman
Sean, I've got the part. I'm waiting to make a short 84 mile run to post temps before install. Then install it there and drive back and post temps then. Just haven't had time to make the trip. That is the only time mine does 30+ spreads. I want to show if it does or doesn't make any difference.
Old Jan 5, 2017 | 01:25 AM
  #30
Yahiko's Avatar
Yahiko
Guess I can wait and see what you come up with. Also I think I can wait on doing any biggish project
until it warms up some. Taking a look at the plastic pipe is an easy thing to do when I change the oil.
I think I will put the replacement of that part along with the a new bypass valve. A new spring with the
valve will be something that should be also done.
hi-jacker
Jan 15, 2018 11:32 PM
Bigfreeb
Aug 31, 2013 08:00 PM
Enomra
Jun 4, 2012 09:21 AM
jmagner
Aug 21, 2011 10:18 PM
Raven855
Jan 21, 2011 08:04 AM
