Delayed start
Old Jan 3, 2017 | 08:11 PM
vinnydiesel27's Avatar
vinnydiesel27
Delayed start
Hi all, I've noticed it takes my truck much longer to start recently. I have 2 brand new interstate batteries, just changed both fuel filters and my truck still takes a good 10 seconds or more of spinning over to fire. Is this normal? I don't remember my truck doing this before, it usually fired right up even in winter. Could this be an injector or glow plug issue?
Old Jan 3, 2017 | 08:54 PM
Pest007's Avatar
Pest007
do you have a monitor or scanner? You might need to check FICM voltage
Old Jan 3, 2017 | 09:30 PM
vinnydiesel27
I have an SCT tuner/monitor. Will that effect the FICM?
Old Jan 3, 2017 | 09:37 PM
WatsonR's Avatar
WatsonR
What year is it?
Old Jan 3, 2017 | 09:42 PM
vinnydiesel27
Originally Posted by WatsonR
What year is it?
It's a 2006
Old Jan 3, 2017 | 09:46 PM
WatsonR's Avatar
WatsonR
Watch the ICP and IPR tomorrow morning when you start it, then post the numbers.
Old Jan 4, 2017 | 08:05 PM
vinnydiesel27
Update: I had some of the guys at the shop where I work take a look at it and they think its definitely a glow plug issue.
Old Jan 4, 2017 | 08:41 PM
fordf150guy's Avatar
fordf150guy
These trucks are pretty good about throwing glow plug codes if any are going out. There are also a few vids on YouTube showing how you can test the glow plugs and harness with a multimeter.
Old Jan 4, 2017 | 09:11 PM
seijirou's Avatar
seijirou
Is it long crank to start worse when cold, the same cold or hot, or worse when hot?
Old Jan 4, 2017 | 09:25 PM
run6.0run's Avatar
run6.0run
Is it endless cranking,, or spitting and sputtering while acting like it might start??
Old Jan 4, 2017 | 09:29 PM
WatsonR's Avatar
WatsonR
^^^ right here is bad glow plug indication^^^ and then it will go. Will do this on 3 bad plugs or more and smoke.
Old Jan 5, 2017 | 10:11 AM
vinnydiesel27
It's worse when it's cold.
Old Jan 5, 2017 | 10:12 AM
vinnydiesel27
More like endless cranking.
Old Jan 5, 2017 | 11:52 AM
WatsonR's Avatar
WatsonR
Time to get some numbers.
eefd105
Dec 5, 2024 05:04 PM
bdave
Apr 28, 2017 04:30 PM
Ford redneck 09
Jan 19, 2015 09:30 AM
sauce216
Sep 2, 2013 09:45 PM
TinyWonder
Nov 8, 2012 09:01 PM
