Adding a Rear Sway Bar
Old Dec 11, 2017 | 01:13 PM
  #136
cecilt's Avatar
cecilt
My dealer quoted $200 for the rear sway bar with the required hardware. Thought this seemed high so I didn't place order. What are others paying?
Old Dec 11, 2017 | 01:21 PM
  #137
Kreep's Avatar
Kreep
That's about what I paid, probably could've/should've saved money by going through somebody like tascaparts.com but I was trying to build a rapport with the local parts guy. That was a waste of time and money...
Old Dec 11, 2017 | 02:35 PM
  #138
petalumaboy's Avatar
petalumaboy
All parts ~ $158 from Tasca which included $38 shipping to California. I have not installed it yet...hope the parts are correct.
Old Dec 11, 2017 | 04:11 PM
  #139
Kreep's Avatar
Kreep
Check your nuts. You need 4 large nuts with clips that slide up into the frame (I think you have these) and 4 large locking nuts that go on the ends of the links (I don't think you have these, part W717497-S439). I think you have a set of small nuts with clips that would slide into the shock mount on the axle, and am curious if you need those and if so do you have the Sterling axle.
Old Dec 11, 2017 | 04:40 PM
  #140
petalumaboy
Kreep - thanks for the heads up. Not sure when I will get back to it. I am suffering from mod ADD. I got sidetracked with new tire/wheel decisions. Squirrel...!
Old Dec 12, 2017 | 08:14 AM
  #141
cecilt's Avatar
cecilt
Ordered from Tascparts as well for $136 including shipping.
Old Dec 12, 2017 | 10:17 AM
  #142
tony m 6.7's Avatar
tony m 6.7
Follow up to my previous thread about clunking noise.
I had my selling dealer install a factory sway bar on my truck. Had a terrible clunking noise. Discovered that the dealer installed the brackets that attach to the frame backwards or inside out. After reattaching the brackets properly, clunk disappeared.
Old Dec 21, 2017 | 01:41 PM
  #143
cecilt's Avatar
cecilt
Originally Posted by Kreep
So I fall in the stock camp. I wanted the 3.31 gears but adding the camper package automatically switched to the 3.55's. So I ordered the gears I wanted and added the sway bar after the fact. Thanks to rjoseph for posting the parts list, my local guy was a little out of his league on this one. I ended up with a slightly different parts list, this one include large nuts for the ends of the links and but not the small nuts for the bushing retainer (the M275 on my F350 already had captive nuts, see pic). Anyway, here's my list:
HC3Z-5A772-A BAR
7C3Z-5486-B RETAINER (2)
HC3Z-5K484-D LINK (2)
HC3Z-5L499-A BRACKET (2)
W500634-S309 BOLT (4)
W500644-S439 BOLT (4)
W717462-S439 NUT (4)
W717497-S439 NUT (4)
These part numbers did not work for me for my 2017 F 350 SRW, 4x4, FX4. Part W717497-S439 does not fit anything. It appears the W717462-S439 are the nuts to attach the brackets to the frame but what is the part number to attach the links to both the bar and the bottom of the brackets? tks
Old Dec 21, 2017 | 01:45 PM
  #144
fleming23's Avatar
fleming23
If anyone in the metro atlanta area wants a used Hellwig, I removed mine from my 250 SRW.
Old Dec 21, 2017 | 01:47 PM
  #145
workingdan's Avatar
workingdan
What was your reasoning for removing it?
Old Dec 21, 2017 | 01:53 PM
  #146
Kreep's Avatar
Kreep
Darn! Sorry about that. Can you post a pic of W717497-S439? I thought that is for nuts you are missing...
Old Dec 21, 2017 | 01:56 PM
  #147
fleming23's Avatar
fleming23
Two things, mine kept making squeaking noises. I lubed all the pivot points but it came back. Probably needed to clean everything really well and just start over. Second, I didn't notice a drastic difference with it connected (although fully disclosure only ran it on the softest setting.) I had the same bar (Hellwig's equivalent at least) on my 2016 F150 but really don't feel the need for it on the 250. Maybe if I had a camper in the bed... This Saturday I am having AirLift bags and auto-leveling sensors installed which will be all I need for the trailer I tow.
Old Dec 21, 2017 | 02:03 PM
  #148
workingdan's Avatar
workingdan
Cool, that should be a good setup.
Old Dec 22, 2017 | 07:25 AM
  #149
bushpilot's Avatar
bushpilot
interesting regarding the squeak....I lubed all the (polly) bushings, inserted them (rubber hammer required ) and run the bar on the middle setting....no squeaks.
I drive this thing like a sports car - and the helwig reduced the body roll in the rear a lot (i had a non adjustable helwig on my 2004 and it made all the difference in the world).
Old Dec 22, 2017 | 09:08 AM
  #150
17 Oaks's Avatar
17 Oaks
My exp with sway bars going back to the 60's and in most cases I went to a larger diameter bar to improve the handling. I never have liked the soft squishy rides of most cars, I prefer the performance gains.
