Thanks for all the part numbers!!! How about the bushings that go attached to the axle? Do you have the part number for those too, once again thank you
If you go with an oversized unit, like the Hellwigs it will come with bushings and brackets, all 3 of mine did...because the swaybar is a larger diameter and you cannot use the OEM stuff, but they still bolt up to the OEM holes...
why bother!?!?! that factory one looks like a coat hanger compared to the Hellwig....AND before you say the BIG Hellwig is too stiff...remember that the Hellwig bar is adjustable (where the factory coat hanger isn't)
I didn't need any special bushings or brackets or part numbers for my hellwig big wig. I ordered it, it showed up at the house, the instructions were excellent. It took about half hour to install without jacking up anything or lifting anything. I did need to put some lubricant on the bolts that bolt the sway bar to the shock brackets. Other than that, it was cake.
It turns out that W500634-S309 (4 bolts that mount bracket to frame) are on back order. It may be a while before I can add my sway bar. Unless I find some online dealer that has them.
Are you trying to order a FORD OEM sway bar???
If so, save your money...an 80 year old man can get stiffer without Viagra than that OEM thing.
Suggest you look back at post # 35 for a camparo of OEM vs aftermarket (Hellwig)...
