Adding a Rear Sway Bar
Old Dec 4, 2018 | 01:41 PM
  #256
Race Red F-250's Avatar
Race Red F-250
Originally Posted by Kreep
I believe that is W500634-S309
Thank you!!! I’ve vascillated on OEM vs Hellwig and started buying OEM parts. It’s been a difficult process, even with the info here. Have received incorrect parts and missing parts from order.
Thanks again for the help!
Old Dec 8, 2018 | 05:21 PM
  #257
blamkin86's Avatar
blamkin86
After a year of use, my Hellwig rear bar is making a terrible racket at the top of the end links near the frame. I don't know if it's the end links, the tabs that go into the frame, or what. But it's really bad now on both sides.
Those of you who use the factory upper mounts - which parts do I need?
I know that Hellwig has a lifetime warranty, I'm going to start with a call on Monday.
Thanks in advance.
Old Dec 9, 2018 | 08:46 AM
  #258
cficare's Avatar
cficare
OEM sway bar Brackets: HC3Z-5L499-A, Bolts: W500644-S439 & Nuts: W717462-S439
You'll need 2 brackets and 4 each of the nuts and bolts. Check the quantity when ordering because the part numbers I listed above for nuts/bolts may be 4-per-package.
Old Dec 9, 2018 | 08:17 PM
  #259
blamkin86's Avatar
blamkin86
THank you very much. I love the bar but the clunking is hard to take on a $60k truck.
Old Dec 10, 2018 | 10:18 AM
  #260
bushpilot's Avatar
bushpilot
a little grease on the bushings will help.
Old Dec 10, 2018 | 10:26 AM
  #261
blamkin86's Avatar
blamkin86
It's actually that tab hanging from the frame rail. It's shifting up and down. The bolt holding it in there is at 60lbft and I don't want to go any further. If the bolt wasn't smaller than the hole it's in, the shifting would stop.
Old Dec 10, 2018 | 04:41 PM
  #262
cficare's Avatar
cficare
Your issue is making me glad I used the OEM frame brackets. BTW, the OEM brackets have a small tab at the bottom that will point outboard once installed, and I snipped (using a grinder) them off so they wouldn't make contact with the Hellwig Big Wig drop-links.
Old Dec 15, 2018 | 01:10 PM
  #263
Race Red F-250
Updated OE parts list
Updated full list of parts for OE rear sway bar, with notes:
Sway Bar (1) - HC3Z-5A772 A (includes bushings)
Sway Bar Brackets (2) - 7C3Z-5486 B (secures sway bar to axle)
Sway Bar Bracket Bolts (4) - W500634-S309 (secures sway bar brackets to axle)
Links (2) - HC3Z-5K484 D (should include the 4 link bolts already installed, arms that connect sway bar to frame brackets)
Link Nuts (4) a W520214-S440 (secures link/bolts to frame bracket and sway bar)
Frame Brackets (2) - HC3Z-5L499 A
Frame Bracket Bolts (4) - W500644-S439 (bolts to secure frame brackets to frame)
Capture Nuts (4) - W717462-S439 (capture nuts that are inserted into frame to secure frame brackets to frame)
Have not compared this list to previous posted here, but just installed the rear sway bar and these parts all worked perfectly on my 2017 F-250 with high capacity towing package.
Thanks to all here who helped with clarifying parts needed. Hope this helps others with the same.
Old Dec 15, 2018 | 03:06 PM
  #264
bushpilot's Avatar
bushpilot
I checked mine, theres no sign of any movement, no rubbing along the frame in any direction.
Old Dec 15, 2018 | 06:50 PM
  #265
blamkin86's Avatar
blamkin86
wonder if I got a dud or something. Not much sign of problem on mine, but when you put a jack under the end of the bar where the link is, it makes a huge pop and shifts upward. Maybe it’s the camper load. No idea. Mine sucks.
Old Dec 16, 2018 | 06:44 PM
  #266
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Installed the Hellwig 1 1/4" sway bar kit today . Easy peasy and fit perfect . Anyone adjust the link to other than parallel ? Just curious .
Old Dec 16, 2018 | 06:58 PM
  #267
cficare's Avatar
cficare
Had to cut/weld my drop-link tubes and shorten them in order to make my bar parallel to the ground. In their shortest position as provided by Hellwig, the front of the swaybar pointed downward because I swapped out my OEM lift blocks for shorter Ford blocks (reverse level). Parallel to the ground is the desired orientation.
Old Dec 17, 2018 | 04:33 AM
  #268
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
I'll stick with parallel . I haven't really driven truck since install and not really sure if I'll notice any difference , but I'll know it's there !!!!! Thanks for the reply .
Old Dec 30, 2018 | 11:41 AM
  #269
pesty3782's Avatar
pesty3782
I have all my rear sway bar parts in the Tasca Cart, but does anybody have a promo code? They want $60.00 for shipping.
Tony P.
Old Dec 30, 2018 | 03:09 PM
  #270
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Tony P.
That's part of the reason I went with the Hellwig !!!
