Adding a Rear Sway Bar
Old Oct 29, 2018 | 09:29 AM
  #226
bushpilot's Avatar
bushpilot
Originally Posted by Race Red F-250
Anyone have a current parts list for OEM rear sway bar addition? There’s a couple different variants of parts lists here (variations in nuts/bolts, mainly) and the couple counter guys I’ve spoken with can’t confirm what/which lists make up the current complete and accurate list.
Why fight it...just order the Hellwig (one part number) and be done w/ it.
You can buy the bar from many retailers (or direct).
Amazon Amazon
Getting way to difficultnto give Foed my money for this; wish they could make ensuring I get the right OEM parts easier. So, I may just go with Hellwig and buy the Ford brackets. Bet I could call Hellwig and they’ll know exactly what I need.
just order it from Hellwig - the kit is complete, one part number, all inclusive.
I went with the "big wig" 7320 adjustable bar from hellwig - its much thicker than the ford version....AND it permits adjustments to stiffen or loosen up the handling.
Old Nov 4, 2018 | 09:05 PM
  #227
Race Red F-250's Avatar
Race Red F-250
Decided to go with Hellwig. Have a F-250 with high capacity towing package and it’s equipped with the F-350 rear End (Dana axle). Anyone know if I need to search for the F-350 Hellwig since it has the same axle? Wasn’t sure if the shape of the sway bar was different for each of the axle options.
Old Nov 5, 2018 | 09:23 AM
  #228
Kreep's Avatar
Kreep
I doubt it will make any difference, but I would order the F-350 kit if I were you. The frames are the same, so the only difference would be axle mounts.
PS: I search high and low but couldn't find my parts list from Ford, sorry!
Old Nov 5, 2018 | 09:40 AM
  #229
Mkos1980's Avatar
Mkos1980
Be careful as the F350 gasser still shares the 10.5 Sterling axle.
Old Nov 6, 2018 | 07:21 AM
  #230
bushpilot's Avatar
bushpilot
Same bar for the 250/350.
I am f350 (SRW) so you'll be safe using the same bar as I am (7320 bigwig adjustable)
If youre still in doubt - I'd call Hellwig. I had occasion to speak w/ them and they were VERY helpful & accommodating.
Old Nov 7, 2018 | 04:14 AM
  #231
workingdan's Avatar
workingdan
selling my bigwig rear sway bar off my 2017 F350 gas SRW if anyone is interested. Local pick up in the Detriot Mi area.
Its a #7294 which was stated would fit my truck but didnt come with the mounting brackets. I called hellwig and they sent out the mounting brackets and new end links so that it is like the #7320.Only had on truck for 6 months. Looking for $275. local pickup only. Dont want to ship.
Old Nov 7, 2018 | 06:14 AM
  #232
17 Oaks's Avatar
17 Oaks
I will ask...why are you selling it? I would take it off your hands were you a bit closer to S Texas.
Old Nov 7, 2018 | 08:20 AM
  #233
Dim Sum's Avatar
Dim Sum
I'm curious too. I'd take it from you as well if I was closer. I have been eying the sway bar mod for my F-250. I was surprised how much airbags actually settled down body roll through so its fallen in my priority list somewhat.
Old Nov 7, 2018 | 12:49 PM
  #234
workingdan's Avatar
workingdan
I dont tow my trailer with my truck, so I removed the sway bar and my air bags, leveled my truck and put on 37" tires. Parts just sit in my rafters now.
Old Nov 7, 2018 | 01:16 PM
  #235
cficare's Avatar
cficare
Here's an unused rear Hellwig listed in the Norflk, VA Craigslist ...
https://norfolk.craigslist.org/pts/d...713479387.html
Old Nov 7, 2018 | 09:48 PM
  #236
bushpilot's Avatar
bushpilot
I don't tow anything either.... I installed the bigwig to take the sway / twist out when NOT towing....truck handles much better (sports car-ish you might say).
Old Nov 8, 2018 | 03:06 PM
  #237
cficare's Avatar
cficare
Same here. If you didn't swap out the front OEM swaybar for a Big Wig, I highly recommend you do so. I did the front swap before adding the Big Wig in the rear, and it felt like the front bar made the bigger improvement in cornering.
Old Nov 8, 2018 | 04:20 PM
  #238
user 474747383's Avatar
user 474747383
Do they make a big wig for the front ?
Old Nov 8, 2018 | 04:49 PM
  #239
cficare's Avatar
cficare
Hellwig Big-Wig FRONT 1-5/16” diameter sway bar PN:7712
Old Nov 8, 2018 | 06:40 PM
  #240
user 474747383
Gotcha, Ok I knew about the 7712, Hellwig just doesn't list it as a Big Wig like they do the rear.
