c6 id help
Old Oct 24, 2016 | 07:41 PM
Bulldog187th's Avatar
Bulldog187th
c6 id help
long story short I have another c6 tranny and I dont know what yr it is.
Since they make two different rebuild kits. On top it says 68 4x4 , looks like it came from a junk yard.
Out side of case looks to me like it is D7-AF-7006-AA
throttlebody inside has number RF-D7AP-7A101-AA
Tail shaft has RF-D4AP-7A300-AA.
So which kit do I need? 1966-76 or 1977-1991?
Old Oct 24, 2016 | 07:42 PM
Bulldog187th
also no metal tag anywhere on outside of case
Old Oct 24, 2016 | 08:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I'm going to go out on a limb and say order the 77-91 kit.
Ford casting numbers can't really be used to reliably check for model years, but you can get a general idea.
The first digit is the decade, D=70's, the second digit is year, 7=7th year, so it looks like the casting numbers indicate 1977 or later.
It doesn't make sense that the D7 would have been from an earlier year.
Old Oct 24, 2016 | 08:53 PM
dlburch's Avatar
dlburch
looks like you should go ask your local John Deere dealer! :-)
Old Oct 25, 2016 | 10:46 AM
Bulldog187th
lol yep. I think this is one of the ugliest trans I have ever seen.
Old Oct 25, 2016 | 11:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since they make two different rebuild kits. On top it says 68 4x4 looks like it came from a junk yard.
1973 was the first year F100/250 4WD's were available with A/T.
Old Oct 25, 2016 | 06:57 PM
Bulldog187th
So I guess im safe to order the 1977-1991 kit. Thanks
Old Oct 25, 2016 | 09:30 PM
matthewq4b's Avatar
matthewq4b
If it's an early C6, the manual valve detent should in the valve body later C6's had it in the case. Also early C6's reverse clutch piston uses a check ball. 77 and later valve bodies have the check ball inside and not in the reverse piston.
Given the casting numbers on your VB I would say it is the later C6.
Old Oct 26, 2016 | 08:53 AM
PA74F250's Avatar
PA74F250
Isn't that a FE pattern C6?
Nevermind its the later one, I had to go look at one which I shoulda done first.
Last edited by PA74F250; Oct 26, 2016 at 09:04 AM. Reason: Didn't know what I was talking about
Old Oct 26, 2016 | 09:13 PM
Bulldog187th
You lost me on the outside dent and inside. Do you have a picture ?
Old Oct 27, 2016 | 12:04 AM
matthewq4b's Avatar
matthewq4b
This would be one for our parts gurus to pull up in an exploded parts diagram.
Old Nov 7, 2016 | 12:43 PM
Bulldog187th
ok here is the Vb
http://imageshack.com/a/img923/2580/bHGaBY.jpg
http://imageshack.com/a/img923/4729/URDpCe.jpg
zombiefied 247
May 23, 2016 06:37 PM
hayden01
13
Aug 10, 2011 02:27 PM
Tat2ed64f100
Nov 10, 2008 04:27 PM
GeneStoner
Jan 5, 2003 05:16 PM
krazdndenver
Aug 5, 2002 12:46 PM
