transmission identification
Old Nov 10, 2008 | 08:03 AM
Tat2ed64f100's Avatar
Tat2ed64f100
Hey All,
I got a 302 with the transmission already on it the block casting numbers say its from a 1972 turino the transmission tail housing numbers are c6ap-7d027-c any ideal if its a c4 or c6 the po told me it was a c6 i looked up the numbers but still am not sure a the c6 at the begining of the number doesn't have to mean its a c6. please all help appreciated
Old Nov 10, 2008 | 08:15 AM
Tat2ed64f100
c4
sorry the po saisd it was ac4 when i asked about the tail housing numbers starting with c6 he said it doesnt mean its a c6
Old Nov 10, 2008 | 11:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All 302's installed in cars/trucks used C4's from 1968 thru 1977.
1978 was the first year a C6 was available in an F100/150, as an option.
1978's have both, most 1979's have C6's.
C4 = 11 transmission pan bolt holes / C6 = 17.
Block casting numbers will not tell what the engine came from, what year it is, or even what size it is, for one simple reason.
Casting numbers cannot be cross referenced to part numbers.
If the block casting number is: D2OE, that doesn't means it's from a Torino, it also doesn't mean it's from a 1972.
Ford may have needed to cast additional bare blocks in 1972 for use as service part replacements.
The block could be anything: 289, 302, 351W, 351C, whatever.
Block casting numbers are worthless for ID'ing just about anything.
Old Nov 10, 2008 | 12:24 PM
daveengelson's Avatar
daveengelson
Not sure if the link posted below is of any help.
https://www.ford-trucks.com/forums/a...8&d=1220647603
Old Nov 10, 2008 | 04:27 PM
Tat2ed64f100
thanks guys for the help
thanks that did help I was going to message you numberdummy I see the two of you post alot of very usefull info. thanks again
whisler
23
Sep 3, 2016 08:11 PM
winger4647
1978 - 1996 Big Bronco
Mar 20, 2016 06:11 AM
wakeboarder32
Dec 23, 2010 09:26 PM
Nuggetfn22004
Jul 21, 2006 01:54 PM
banky
Jun 13, 2006 08:15 AM
