C6 casting numbers?
Old Jul 27, 2011 | 11:46 PM
hayden01's Avatar
hayden01
C6 casting numbers?
Im going to be putting a C6 in my '84 Bronco for the time being. Today I was changing the filter on it I found some numbers on the back of the tranny, by the tail shaft, They are:
3 356A1 76617 A
I also found on the valve body these other numbers:
D7AP-7A101-AA
LESTER-3
Mainly concerned about the numbers cast into the transmission housing by the tailshaft. Thanks for any imput. Hoping to find out what year C6 it is so I put the right ATF in it.
Old Jul 28, 2011 | 11:13 PM
85e150's Avatar
85e150
D7AP is 1977 fwiw, which ain't much.
Look for a date code in this format: "7/2011".
Old Jul 29, 2011 | 03:29 AM
hayden01's Avatar
hayden01
Alright so she's a '77 C6 then cool... today when I was giving the C6 a good cleaning before I put it in, I found a tag with another set of numbers on it:
PGD DL1 M23
E1TP CA 023674
I found these on a tag on a bolt that bolts on the servo on the passenger side of the tranny. Just wondering if there is a site I can go to to decypher these numbers? Thank you.
Old Jul 29, 2011 | 05:38 AM
Ken Blythen's Avatar
Ken Blythen
1977 was the first year for Mercon/Dexron fluid in C6's;
76 & earlier used Type F (unless rebuilt with later clutches, bands etc).
The E1TP number is from 1981
Old Jul 29, 2011 | 06:17 AM
hayden01's Avatar
hayden01
Thank you Ken. Would those numbers tell if it is a 3 speed or 4 speed? Im really hoping its a 4 speed with overdrive.
Old Jul 29, 2011 | 12:34 PM
85e150's Avatar
85e150
A C6 is ONLY a 3 speed non-OD, non lockup trans.
Old Aug 9, 2011 | 04:06 AM
hayden01's Avatar
hayden01
Im not to keen on AT lingo, non-lockup trans meens what again?
Old Aug 9, 2011 | 04:33 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It means the torque converter doesn't have a clutch inside it. It slips all the time.
Old Aug 9, 2011 | 04:48 AM
hayden01's Avatar
hayden01
I thought sliping was bad as it wears things out quicker?
Old Aug 9, 2011 | 10:00 AM
mark a.'s Avatar
mark a.
It isn't sliping like clutches can do. A tc is a hydraulic cuppler so there no possitive/ mechanical lockup. There will always be some degree of slip in a tc.
Old Aug 9, 2011 | 10:47 AM
Mark Kovalsky
If you want to know more about torque converters and lockup clutches there is a good article at HowStuffWorks - Learn How Everything Works!
Old Aug 10, 2011 | 02:59 AM
Ken Blythen
As 85e150six4mtod said, the C6 is only a 3spd, but it's a much better suited transmission to a truck, or any hard working vehicle, than an AOD or AODE (which were 4spd's). The C6 is much heavier duty, simpler, & less expensive to eventually rebuild.
I've had each in my truck & I prefer the way that the C6 operates.
But the C6 is old-school (an auto-trans mechanic I know calls them "agricultural" ) & doesn't have the economy of either lockup or overdrive, if that's what you need.
Old Aug 10, 2011 | 03:14 AM
ford390gashog's Avatar
ford390gashog
Those casting numbers are Ford engineering numbers and not when it was made! But Either way Mercon of Type F will be fine in the unit and Type F provides firmer shifting with less slippage!
Old Aug 10, 2011 | 02:27 PM
85e150's Avatar
85e150
That is true, but note that an "E1.." casting is going to be NO OLDER than 1981, or a "D7.." NO OLDER than 1977.
zombiefied 247
May 23, 2016 06:37 PM
Tat2ed64f100
Nov 10, 2008 04:27 PM
GeneStoner
Jan 5, 2003 05:16 PM
klondike
Jul 31, 2001 06:42 AM
