Middle long drive cel
Old Aug 27, 2016 | 07:00 AM
btm991's Avatar
btm991
Got a cel and don't have a scanner I'm currently in the middle of the desert put the truck into engineering mode and saw dtc c46282, would this cause the cel and anyone know what the code is for? Thanks all
Old Aug 27, 2016 | 08:43 AM
Just Strokin's Avatar
Just Strokin
What about a little info about your truck? Year would be a good start. Not sure if the DTC is correct. Usually one letter and 4 numbers, not 5. Also, know of no DTC that begins with C.
Old Aug 27, 2016 | 09:47 AM
Double-Trouble's Avatar
Double-Trouble
From this thread: DTC 46282 is related to compass calibration on your old non-navigation system.
https://www.ford-trucks.com/forums/1...roblems-2.html
Old Aug 27, 2016 | 02:25 PM
L3dford's Avatar
L3dford
The DTC codes shown in the engineering mode in the info display are for the gauge cluster not for the truck. You can't get the truck codes unless you are plugged into the OBD port under the dash.
Old Aug 28, 2016 | 11:24 PM
btm991's Avatar
btm991
Okay so then since this code is seen in engineering mode this must not be the cause of the cel, correct?
Old Aug 28, 2016 | 11:28 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Yep you are correct the CEL is from something else.
srusse95
Mar 13, 2018 07:41 AM
Idahoser
Nov 17, 2011 12:33 PM
wolffee
Aug 26, 2011 11:07 AM
supercrew8131
2004 - 2008 F150
May 15, 2006 11:08 PM
busdriver47
Jan 6, 2006 05:32 PM
